20 Most Recent Logitech EX100 967499-0403 Keyboard Questions & Answers
Take the keyboard and its receiver (&driver if necessary) to another machine. If it works there then it is a driver issue with your computer. If also dead then time to go shopping.
Logitech EX100... | Answered on Sep 06, 2017
try replacing the key board battery or make sure that it is the correct way
Logitech EX100... | Answered on Jul 21, 2017
Hi Mark...is it only one of the [SHIFT] keys that is non-operational? If so, please see the instructions I've posted for a similar problem:Number 1 appears to be stuck
It's quite likely this solution will fix your problem as well, but if not, please let me know and we can try a few other solutions.
Thanks,
Mikeal
Logitech EX100... | Answered on May 24, 2014
Try to Update your driver may it will work for you here are the easiest step for updating the drivers:
On Desktop
Right click on My computer icon and select Properties
Click on Device Manager
(Or follow Start button --> Control Panel --> Device Manager)
Now search for your hardware whom you want to update.
Right click on it and click on Update Driver Software...
It will ask for CD or DVD then insert the driver CD/DVD if you don't have then it will ask for searching the drivers over internet click Yes for it and it will automatically download the drivers for you.
Or you can use Third party software which can search,Download and Update them for you without making much effort.
Click here for Driver Updating Free Software's
Thank You...
Logitech EX100... | Answered on Sep 11, 2011
Welcome to FixYa!
i think there is some sort of obstruction , that's not letting the keyboard ? and shift key to press.
lift the keyboard and try to get it upside down.and hit it hard so any thing that's stuck should drop down . or see closely and check whats jamming the buttons i hope you get your answer
Do comment if it helps you in any manner
Logitech EX100... | Answered on Apr 17, 2011
you should try downloading the keyboard drivers from the below mentioned web-site...
http://drivers.softpedia.com/get/KEYBOARD-and-MOUSE/LOGITECH/Logitech-Cordless-Desktop-EX-100-241.shtml
Logitech EX100... | Answered on Apr 05, 2011
i just got off the phone with logitech tech support about my 'dead keyboard'. I have a logitech wireless keyboard/mouse ex100. the mouse still worked and the keyboard just quit all of the sudden like. THE FIX! 1. Make sure in your device manager that the keyboard is still connected and working properly. if it is...
2. then remove the batteries and type on the keyboard for 10 seconds or so.
3. Then reinsert the batteries.
4. press the left alt key, left control key, and the f12 key all at the same time.
5. Then press the connect button on the reciever
6. press the connect button on the keyboard
7. press the escape button on the keyoard
8. test the keyboard
it worked for me :) that's how i was able to type this. hope it works for you
Do a Hard Reset method to clear the keyboard and mouse settings and reconnect it back to your computer:
• Remove the batteries from the keyboard
• Press the Connect button on the receiver for 10 seconds.
• Press the Connect button on the mouse.
(You might need a pencil tip or other small tip to press the connect button.)
• Insert the batteries back into the keyboard.
• Press the Connect button on the receiver.
• Press the Connect button on the keyboard.
Hope this helps
Please rate this solution, thanks!
Logitech EX100... | Answered on Mar 08, 2011
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
also
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have a virus also select users you will see who is using your computer
you might have to many programs loading at start up or you might have a virus run your antivirus program then
click start control panel keyboard hardware then properties you should see driver details,you will have options to update driver,roll back driver,uninstall
make sure you have the driver for the keyboard before uninstalling the driver
make sure the lead is good and has a secure connection diconnect the keyboard then reconnect it then reinstall the driver
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
as for the mouse
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options also hardware under hardware you can troubleshoot or
select properties under driver you will have the options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
dont forget to vote
hope this helps
Logitech EX100... | Answered on Feb 07, 2011
i've experienced the exact same problem :
mouse working ok, but i was unable to get any response from the keyboard.
i tried to update the drivers, i tried reinstalling the drivers on a clean boot, nothing would do. but then i tried to use my computer with a classic usb keyboard, which caused xp to detect both keyboards on startup, without managing to install either of them.
so that's how i found out my problem, which i hope is also yours, was that the proper driver for usb keyboards is not signed. so somehow xp would refuse to use it. forcing a manual install of that unsigned driver on both keyboards made the both of them finally work.
so if you have not tried that yet, i suggest you to reinstall your keyboard driver
without letting windows select the driver automatically (forgive any clumsy translation, i'm running a french version) :
1. find your keyboard in the device list (configuration panel > system > hardware > device list)
2. right click on it, go to properties, and choose reinstall driver
3. the installation wizard is then launched, tell him you wish to specify the location of your driver
4. in the second step of the wizard, tell him not to search for the driver, you'll select it manually from the list
5. in the list that appears next, select Human Interface Devices (my driver was in the HID section)
6. among the drivers in that section (there were 2 in mine), one of them is not signed, select that one and install it.
that's how i got my keyboard to work, hope this may be helpful to you in any way
Logitech EX100... | Answered on Dec 19, 2010
look just after the F12 key, there should be an insert key on that model keyboard, may be hard to spot or in a different colour writing.
If you still cant find it, use the on screen keyboard's insert key
1. Click on Start and click on "Run"
2. Type osk and click OK.
3. You will see the On Screen Keyboard (OSK)
Logitech EX100... | Answered on Oct 31, 2010
The Scroll Lock is function is activated by pressing the blue function key (between the right side ALT and CTRL keys) and "PAUSE/BREAK" (right-most key in the top row).
Logitech EX100... | Answered on Oct 17, 2010
after installing the driver chek if the keyboard and mouse have batteries the press the button onthe wireless receiver then press the red button under the mouse wait 10 seconds then press the red button under the beyboard thys should work.i have the same keyboard
Logitech EX100... | Answered on Aug 16, 2010
Logitech EX100 967499-0403 Keyboard Logo
61 questions posted
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Computers & Internet
Most Popular Question
backslash question mark right shift
  • Computers & Internet
