20 Most Recent Mackie Cfx16 Mk Ii Mixing Board Questions & Answers
0answers
Ive got a 1801 mackie sub. Humming/ buzzing with no other sounds. Signal light is bright, doesn't flicker like the overheads. Thanks in advance.
Why does my subwoofer make a humming noise? The voltage difference between a subwoofer electrical ground and the equipment ground can cause it to hum. This can happen because of the irregular current flow in your audio cable. Turning on the volume too high can also cause a hum.
5/15/2021 8:39:49 AM • Mackie Audio... • Answered on May 15, 2021
I have a Berhinger B115 that works fine for about 20 minutes or longer at about 1/2 power and then shuts off. Wait 10-15 minutes and it will turn back on. I had this issue with an active Mackie speaker years back and it was a protective relay that was failing. Any chance that someone would have a schematic and a place to order parts?
Hello Redman, I sent you the link to download the service manual of model B112, it is quite similar Check for possible false contacts I hope you can solve the problem Greetings Franco Dosil Hola Redman, te envio el link para que descargues el service manual del modelo B112, es bastante similar Revisa posibles falsos contactos Espero puedas resolver el problema Saludos Franco Dosil https://elektrotanya.com/behringer_eurolive_b112d_sm.pdf/download.html http://www.uns.nu/pdf/Behringer_Speaker_B115D.pdf
7/5/2019 4:55:42 PM • Mackie Audio... • Answered on Jul 05, 2019
My Mackie Tapco speaker makes a awful loud buzzing sound when powered on. Why
Sounds like an earthing problem , check your cables and make sure none of the cables have strands that could be shorting down to earth causing the buzz
1/13/2019 5:52:48 PM • Mackie Audio... • Answered on Jan 13, 2019
2answers
Mackie srm450 amplifier low sound
are you running a sub, daisy chained to it? are they connected to each, just have one, two, four? are you hooked up like in the pic? 26425296-rpqltah4fv1m3mnct1w42zea-3-0.png
1/4/2017 8:16:15 AM • Mackie Audio... • Answered on Jan 04, 2017
How to connect subwoofer power speaker to mackie mixer 1604
http://www.billebro.se/proddoc/PRID_5420_doc_swa1501_om.pdf
11/9/2016 10:49:55 PM • Mackie Audio... • Answered on Nov 09, 2016
Mackie subwoofer srm1801 is chirping, what could
Hi. Did you get diagnosis for this? Mine has developed the same fault...
8/28/2016 8:29:30 AM • Mackie Audio... • Answered on Aug 28, 2016
Mackie fr series m-1400 pro amp not working, no power, fuse not blown
output finals are shot,and get the caps checked also.
2/2/2015 6:53:06 PM • Mackie Audio... • Answered on Feb 02, 2015
Do you have a mackie 1530z schematic?
Mackie will send schematics free-o-charge.
6/4/2014 9:05:52 PM • Mackie Audio... • Answered on Jun 04, 2014
Is there a 1530z schematic?
Mackie will send schematics free-o-charge BUT surface mounted electronic components are no cakewalk to repair. If's it's a fuse, cool but if not it may be best sending it to the pro's for repair.
6/4/2014 9:04:50 PM • Mackie Audio... • Answered on Jun 04, 2014
Mackie Cfx16 Mk Ii Mixing Board Logo
1 questions posted
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Eric
ADMIN Eric
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Mackie Audio Players & Recorders
Most Popular Question
mackie pro fx8 starts blinking all
  • Audio Players & Recorders
