20 Most Recent Toshiba 50HP66 50" Plasma HDTV Questions & Answers
The manual is here
https://tvna.compal-toshiba.com/us/wp-content/uploads/sites/2/2016/09/toshiba-43_49_55_65l621u_16-0706_web_v2_en_final_lr.pdf
The connection for external speakers like you have is called analog audio output and it is shown with a little set of headphones next to it. The issue is the size of that jack. There are two basic sizes 3.5 mm and 2.5 mm . The manual does not say which one is on your television. If you have a set of headphones you can try that would let you know. Otherwise it is trial and error. What you need to do is get a cable that has that end on it and then make the connection to your speakers. Using the wires on the speakers you need to be able to tell what polarity they are and connect two of them to one of the wires in the cable that you found that fits the jack. These are the ground connection and on the cable the ground is usually a bare wire strand. Then the other two cables that are remaining, connect to each of the wires that are coming out of the connection to the television ( they should be colored) One goes to each for left and the other for right. You may want to solder them and make sure that you tape or insulate them against shorts.
Toshiba Audio... | Answered on Sep 08, 2018
suspect you have a broken wire ,we can not fix it here see someone that can physically test it and possibly solder wire
Toshiba Audio... | Answered on Aug 16, 2018
They make usb mics. also there are ones that plug into your mic input jack, If you are really serious about your singing and want to invest a little more money you can get a AD/DA converter (analog to digital and digital to analog) here is a link.
https://www.sweetwater.com/c796--AD_DA_Converters
And every vocalist worth their salt needs as good a mic as they can afford. For $158.00 this mic is Durable with a wonderful sound and the price is affordable. This is a proven winner
https://www.sweetwater.com/store/detail/Beta58a
Then there is software for recording starting out with open source
software recording software audacity
Top of the line would be Pro-Tools by Avid
recording software pro tools
What ever kind of software you get there is a learning curve
and most JR. Colleges offer classes and there are on line
sources also like:
Lynda
https://www.lynda.com/signup
and Groove3
https://www.groove3.com/about-us?gclid=CjwKCAiAvMPRBRBIEiwABuO6qV_9oXo5TopXi-SyrEVrQOFky5L8F55O5VCAVNH_oL3No0nVPGwAqBoCqQgQAvD_BwE
There a lot of ways to go and if you start your journey by setting small goals and achieving them....Soon you'll have bigger fish to fry......Good Luck...........~~~~~~~~*BB
Toshiba Audio... | Answered on Dec 13, 2017
Toshiba 50HP66 50" Plasma HDTV Logo
2 questions posted
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
JohnLong
Blake Whiteside
Level 1 Expert
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Audio Players & Recorders
Most Popular Question
connecting klipsch screw terminal
  • Audio Players & Recorders
