20 Most Recent Rotel Rsx-1065 Receiver Questions & Answers
E76-LE2-2/45 TK-1 transformer data sheet
Service manual says it has already selectable voltage transformer in it having selection of 120V, 220V and 240VAC. Anyway see page 9 of service manual ROTEL RX-855 Service Manual download, schematics, eeprom, repair info for electronics experts (elektrotanya.com)
10/27/2023 1:25:19 PM • Rotel Audio... • Answered on Oct 27, 2023
2answers
ROTEL RCD-951 TM can not open tray.
Hello Ruben, so you do not open the CD holder tray of your Rotel, the problem is that the belt that transmits the rotation of the engine to the mechanism of the car, may be stretched and therefore the car does not open, this is the most common fault in this type of CD players You should replace it, if you can not do it, look for a specialized technical service I hope you can solve the problem Greetings Franco Dosil Hola Ruben, por lo que cuentas, no se abre la bandeja porta CD de tu Rotel, el problema es que la correa que trasmite el giro del motor al mecanismo del carro, puede estar estirada y por lo tanto el carro no se abre, esta es la falla mas habitual en este tipo de reproductores de CD Deber?s reemplazarla, si no puedes hacerlo, busca un servicio t?cnico especializado Espero puedas resolver el problema Saludos Franco Dosil https://elektrotanya.com/rotel_rcd-951-tm.pdf/download.html http://bwgroupsupport.com/downloads/manuals/rotel/RCD-951-OM.pdf
10/9/2021 5:20:27 PM • Rotel Audio... • Answered on Oct 09, 2021
I have an old surround sound reciver ROTEL RSX-1067 Mabee 20-30-40 years old : one day it just shuts down, just like that.
Several possibilities come to mind. First shorted connections to speaker wires. Faults in the power supply. Sometimes if the unit has not been working for a while the large capacitors in the power supply can dry up. An overload on a power transistors.
6/5/2021 2:58:48 PM • Rotel Audio... • Answered on Jun 05, 2021
I have a rotel rb970bx. I have 2 and ran them in
hi it sound to me that when you biamp and driving speaker and woofer , you are over loading the fuses , suggestions uprate the fuses till they stop blowing
12/21/2017 9:15:36 PM • Rotel Audio... • Answered on Dec 21, 2017
Rotel rsx 1065 switches on. every single thing is lit up in the display panel on receiver. But unable to select anything and of course no sound. what could be wrong?
Probably the EEPROM, the heart and brain of the appliance. I had the same issue with my AIWA, could not figure out the cause, took it in, tech told me EEPROM is blown. Not economical to repair.
11/20/2017 6:03:23 PM • Rotel Audio... • Answered on Nov 20, 2017
Rotel rcc-1055 won't stop spinning carousel. It will sometimes play a disc but mostly spinning looking for a disc
Your changer has lost its mind and is doing crazy things.just like mine. Software issue not repairable.. Go shopping.
9/13/2017 1:38:23 AM • Rotel Audio... • Answered on Sep 13, 2017
0answers
3answers
HALLO I HAVE A ROTEL RA 9858X AND AGTER PLAYING FOR A FEW MINUTES I LOSE THE RIGHT SPEAKER CHANEL
Try interchanging the speakers. If the right channel works, you have a problem with your speaker.
11/19/2016 3:33:44 PM • Rotel Audio... • Answered on Nov 19, 2016
Rotel RHB-10 amp not firing up anymore; protection light/cicuit not engaging
Check the rest of the power supply, for example the transformer if there is no power at all. If you are getting some indication of power, check the voltage regulator circuit.
4/30/2016 3:24:01 PM • Rotel Audio... • Answered on Apr 30, 2016
My Rotel RSP-976 analog inputs don't produce sound. I did all the OSD settings but to no avail
Hi Awal. Interesting problem. Have you tried another pair of leads? What source are you using please, cd tuner etc? I noticed the the names for the five audio/video inputs can be customized by the user, Maybe there is a firmware issue? With the unit being surround sound Have you tried running in 2 chanels only?
1/16/2015 3:20:23 AM • Rotel Audio... • Answered on Jan 16, 2015
Rotel Rsx-1065 Receiver Logo
2 questions posted
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Larry
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Rotel Audio Players & Recorders
Most Popular Question
rotel rhb 10 amp not firing up anymore
  • Audio Players & Recorders
