20 Most Recent
Definitive PF 15TL+ Subwoofer Speaker Questions & Answers
Loud buzzing noise.
If you pull out the "input" cables and the noise stops, you have a problem with the "ground" and you have to check if there isn't a loose contact inside the plugs. If it doesn't stop, your amplifier is the problem and that mostly is a bad contact on the board in the pre-amplifier area.
My definitive technology pro cinema 600 sub stopped working
theres a setting is on the subwoofer itself, not the AVR. It usually has 3 positions: On, Auto, Off. Auto allows the sub to "sleep" when it's not being used, and to power back up fully when it senses a signal. Maybe change to On position which would bypass that auto mode
I have a Definitive C/L/R
If you can figure out the diameter you can look around the web or eBay for speaker repair kits to replace the foam.
My definitive powerfied subwoofer keeps
a downed circuit is causing your problem it needs to go into the shop to have the fault found and repaired the cost is minimal our company charges less than $ 60 for this fault
good luck
sonic boom electronics
please click helped if this does
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
