20 Most Recent Samsung Pn60e7000 60 Inch 1080p 3d Wifi Plasma Hdtv Questions & Answers
What can do to fix my tv?
Try vacuuming the back of the vents, or carefully use compressed air. a fan might help, if the tv is in a tight spot and not getting proper air circulation .
9/3/2015 4:58:55 PM • Samsung... • Answered on Sep 03, 2015
Samsung VP-D352 pulling out tapes
1/7/2024 12:34:59 PM • Samsung Video... • Answered on Jan 07, 2024
Samsung VP-D103i. Mini DV tape with LP recordings have distorted audio. How to fix please?
Try cleaning the heads. There isn't much on the subject. You could try specialist AV Forums. https://www.google.com/search?q=Samsung+VP+D103i+correct+distorted+audio+on+LP+recordings ..
8/19/2023 4:54:30 PM • Samsung Video... • Answered on Aug 19, 2023
How do I get my Samsung sc d 353 mini DV tape recordings on computer
To transfer the recordings from your Samsung SC D353 Mini DV tape to your computer, you'll need to follow these steps:
1. Connect the camcorder to your computer: Use a FireWire (also called IEEE 1394) cable to connect your Samsung SC D353 Mini DV camcorder to your computer. Most computers have a FireWire port, but if yours doesn't, you can purchase a FireWire adapter card.
2. Turn on the camcorder: Turn on your Samsung camcorder and set it to VCR mode.
3. Open the video capture software: On your computer, open the video capture software that came with your operating system (e.g. Windows Movie Maker, iMovie on Mac) or a third-party video capture software (e.g. Adobe Premiere Pro, Final Cut Pro) that supports Mini DV tape.
4. Start recording: In the video capture software, select the option to capture video from a DV device. Click the Record button in the software and then press Play on the camcorder to begin playing the Mini DV tape. The video should be captured and recorded onto your computer.
5. Save the video: Once the video has been captured, you can edit it if necessary and then save it to your computer in the desired format.
Note: If you do not have the original video capture software, it is recommended that you search and download compatible software before beginning the transfer process. Additionally, make sure your computer has enough storage to store the transferred files.
3/14/2023 1:37:34 AM • Samsung Video... • Answered on Mar 14, 2023
Samsung SC-D353 foggy lens - what can I do?
If the lens on your Samsung SC-D353 camcorder is foggy, there are a few steps you can try to clear it:
  1. Clean the lens using a lens cleaning solution and a soft, lint-free cloth. Be sure to gently wipe the lens in a circular motion, taking care not to scratch it.
  2. If the foggy appearance persists, there may be moisture inside the camcorder. You can try using a hair dryer or a can of compressed air to blow out any moisture that may be trapped inside the camcorder.
  3. If the foggy appearance is still present after trying these steps, there may be an issue with the lens itself. In this case, you may need to have the camcorder serviced by a professional.
I hope this helps! If you have any further questions or if you are having trouble clearing the foggy lens on your camcorder, don't hesitate to ask.
1/7/2023 11:23:31 PM • Samsung Video... • Answered on Jan 07, 2023
2answers
Samsung VP-D103 flashlight not turning off.
Hi, Please remove the memory card and hold the power button down for 15 seconds. If that does not turn the light off, please remove all batteries from your device. Please stay away from the power outlet where the camcorder was initially charging. Thank you.
10/6/2022 7:35:24 AM • Samsung Video... • Answered on Oct 06, 2022
Samsung NX Mini-Camera. Can I use the camera as a webcam?
Question edited for clarity. Question mover from Samsung Television. Apparently you can. See the videos. https://www.google.com/search?q=use+my+samsung+nx+mini+camera+as+a+webcam ..
5/22/2022 7:46:07 PM • Samsung Video... • Answered on May 22, 2022
I have an old Samsung VP-A30 8mm Video camera with loading problem.
dead or weak battery
10/31/2021 1:08:00 PM • Samsung Video... • Answered on Oct 31, 2021
Driver for Samsung SCD6040
Log in to Samsung web site , enter make and model on the driver site. if there is a update driver download it there .
8/18/2021 3:53:05 AM • Samsung Video... • Answered on Aug 18, 2021
Samsung SCL860 Camcorder playing tapes in double-speed. Help!
I would check to see if the correct sync pulses are getting to the servo processor firstly.
4/10/2021 8:29:50 AM • Samsung Video... • Answered on Apr 10, 2021
How do I connect the samsung vp-w80u camcorder to
How do I get colour on my Samsung digital camcorder vp-w80u 8mm
3/22/2020 10:36:49 PM • Samsung Video... • Answered on Mar 22, 2020
Hello, i have Samsung camera recorder vp-u12 i don't how to start it how to start recording
put a fully charged battery, there is a changeover switch
2/29/2020 8:53:12 AM • Samsung Video... • Answered on Feb 29, 2020
Can the samsung camcorder hmx q20 be used as a webcam
If you are having issues with an app, or multiple apps, there are a few things you can try to resolve the problem. Clearing the app cache, updating the app, rebooting your device,.
2/12/2020 6:51:26 AM • Samsung Video... • Answered on Feb 12, 2020
Unlock samsunge 3210 phone pls
By using Unlock Code you can unlock your Samsung e 3210 . You can get the unlock code from Superunlockcodes.com . There you need to specify your Country and Current network name to get the unlock code. They will give you unlock code along with instructions on how to unlock. Follow the instructions and unlock your Samsung e 3210 .
11/13/2019 3:51:38 AM • Samsung Video... • Answered on Nov 13, 2019
Samsung SC-D365 Digital Video Cam user manual
On the internet call up :
http://www.samsung.com/us/
Then in the upper left of the screen labled "Find" type in "SC-D365". Then click on "Users Manual" . You'll have to be able to download a PDF file.
10/29/2019 12:16:11 AM • Samsung Video... • Answered on Oct 29, 2019
2answers
I need to download the manual
Can you state here the model of your camcorder?
Also, there is a website for all Samsung products:
http://www.samsung.com/us/support/download/supportDownMain.do
Just input the correct model. It will give you a list of files - drivers, manuals, etc.
10/17/2019 1:58:29 AM • Samsung Video... • Answered on Oct 17, 2019
Samsung Pn60e7000 60 Inch 1080p 3d Wifi Plasma Hdtv Logo
4 questions posted
Top Samsung Video Cameras Experts
302lab
Level 1 Expert
NOEL
NOEL
 Grubhead
Grubhead
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Video Cameras
Most Popular Question
fix tv
  • Video Cameras
