20 Most Recent
Samsung N145 Plus 10.1 inch Netbook - Black Intel Atom N455 1.66GHz, RAM 1GB, HDD 320GB, LAN, WLAN, Webcam, Windows 7 Starter Questions & Answers
Restore a Laptop Keyboard b> When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement. Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it. If its still not working Tap the "Alt" and "Shift" keys simultaneously if you are pressing one keyboard key and getting a different symbol or letter. This will reset the keyboard defaults on some laptops. Press the "Ctrl" key and tap the "Shift" key simultaneously if the procedure in Step 1 did not work. Press the "Fn" and one of the "F" keys to disable the "Num Lock." Different laptops use different "F" keys to disable the "Num Lock." Toggle each "F" key and press the "Fn" key at the same time to find the right key combination. Check your laptop manual to find the right key combination. Press the "Fn" key and the blue "NumLock" key simultaneously if the keyboard is typing numbers instead of letters or wrong letter keys and the above steps did not solve the problem. b> Keyboard Maintenance b> Blow compressed air in the cracks and crevices of the laptop keyboard. Sometimes dust and debris can cause keys to lock, making such keys non-functional. Disconnect the laptop from the power outlet and remove the battery. Make the tip of a cotton swab as thin as possible by rolling it between your finger tips. Dip the thinned cotton swab in rubbing alcohol and clean the crevices of the keyboard with the cotton swab. Continue cleaning between each key of the keyboard with the alcohol-dipped cotton swab. Use a new cotton swab whenever necessary. Slightly tip up one side of the laptop so dust will move from under the keys to the crevices so you can clean. Blow compressed air into the keyboard again as you did in Step 1 of Section 2. Reconnect the computer to the power and check to see if the issue is resolved. Insert the flat edge of a flat-blade precision screwdriver under a keyboard key and gently pry it up and off. Remember where the keys go, so you can easily replace them. Remove three keys at a time and clean with a cotton swab dipped in alcohol. Replace the keys and remove the next three. Do this until the entire keyboard has been cleaned. Disconnect the laptop from the power outlet and remove the battery again. Turn the computer so the rear is facing you. Remove the screws that hold the plastic hinges in place. Insert a small flat-blade precision screwdriver in the plastic hinge seam and pry the hinges up. Turn the computer back face forward and open the screen as far back as it will go. Continue lifting the plastic hinge and power plate until it comes off. Remove the screws you see holding the keyboard with a precision Phillips screwdriver. Blow compressed air under the keyboard. Lift the cable connector levers slightly and remove the data cable. Clean the cable pins with an alcohol-dipped cotton swab. Replace everything, power on the computer and try the keyboard again to see if the issue is resolved. b> Keyboard Replacement b> Connect an external keyboard to the USB port on the laptop and verify its working condition. Disconnect the external keyboard and verify that the keys on the laptop are still inoperable. Disconnect the laptop from the power outlet and remove the battery. Remove the laptop keyboard as you did in Step 3 of Section 2 by removing the plastic hinge and power button plate, the keyboard screws and disconnecting the data cable from the motherboard connector. Replace the keyboard with a new laptop keyboard for your laptop make and model. b>
Manufacturer's Website: Go to the manufacturer's website (visit the official Samsung website in this case). Click on the support section, search your monitor model by product name or model number, and download your monitor model for the user manual. User manuals usually list codes and other relevant information.
User Manuals Online: Many people post user manuals online for all types of electronic devices and peripherals. You can search for your monitor and look for the user manual at sites such as ManualsLib, ManualsOnline, or Retrevo. Most of these sites will catalog user manuals for a wide variety of devices posted online by users and are normally free to access.
Physical User Manual: If you still have the original box or packaging with your monitor, there might be a copy of the user's manual in that box or enclosed. It might be in an actual printed booklet or perhaps just some links to online resources. Check under a section entitled 'Remote Control Codes' or 'Setup Instructions'.
Contact Samsung Support: If no luck finding it to download or to help you, there is contact support available, they should know where that information is, and be able to send it to you or refer you.
With these, you should be able to find the user manual for your Samsung 32" curved screen display and enter those codes.
ENGLISH ONLY please.
Samsung washing machine wf90f5e5u4w
Hello good afternoon, I want to ask for help, I have a faulty module and I wanted to ask if you have the electronic diagram for the Samsung DC92-01240C washing machine, the machine model wf90f5e5u4w, I would really appreciate it if you could, thank you. greetings Antonio Paulo
Sounds like the phone is on a contract with a different supplier.
Contact the original SIM supplier, EE, O2, Vodaphone etc and ask them to unblock the phone.
Question edited to add the further information.
Has to be in the manual? Did you pull the mains plug overnight?
That panel is called OSD (on screen display) and can be set to stay on for up to 200 seconds. Page 39 refers, and you can also reset it to factory defaults.
https://downloadcenter.samsung.com/content/UM/200803/20080329132905671_BN59-00716A-Eng.pdf
That sounds like a voice command problem for this Chicago, Illinois based channel. Refer to the station by its number on your subscription package, like "Alexa channel 1105 on tv".
https://www.google.com/search?q=wgn+-+tv
Samsunghttps://www.samsung.com > answer > ANS00087622
Amazon Alexa is now built-in on Samsung TVs and smart monitors! You can ask Alexa to change the channel, open apps, search for movies and shows, play music, ...
Tom's Guidehttps://www.tomsguide.com > How-to > TV
Apr 5, 2023 - Step 1: Set up your devices. First, make sure that both your Samsung TV and your Amazon Alexa device are set up and workings.
Can Alexa change TV channels? As long as you're using the TV's built-in tuner, you can use Alexa to change TV channels. Just say something like "Alexa, channel 7 on TV" or "Alexa, change channel to [channel name] on [TV name]."Nov 1, 2022
Plasma is old technology and it is 16 years old and made in Mexico, the worst place for quality control. It is time for a new one, or at least an upgrade. Or you can get a board kit and take a chance on fixing it.
