20 Most Recent Buffalo Technology AirStation WLA2-G54L 802.11g/b (WLA2G54L) Wireless Access Point Questions & Answers
Try this:
Reset the Airstation to factory settings by holding the reset button until the lights flash (10 seconds).
Once the airstation has been reset, reset it changing your password.
Below are the instructions on how to setup your Airstation.
http://www.columbia.edu/acis/networks/aptnet/buffalo/index.html
Good luck!!
Buffalo... | Answered on Aug 17, 2012
put it on pass word protection.
Buffalo... | Answered on Feb 13, 2011
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Buffalo... | Answered on Feb 04, 2010
you are using the wrong username and password
Buffalo... | Answered on Jan 10, 2009
when you say you tried to upgrade your firmware, are you talking about in your router or your Access Point?
Buffalo... | Answered on Jan 09, 2008
The message "The Request Could Not Be Performed Because of an I/O Device Error" appears when Windows is unable to read the data on a storage device.
If this error message appears when attempting to access the files on an input/output (I/O or IO) device, such as an external hard drive, the file system on the drive could be damaged, the drive could be infected with a virus or the data connector inside the device enclosure could have come loose.
If troubleshooting the drive fails to fix the IO device error, formatting the drive might repair the device.
Connect the external hard drive to the computer.
Run an antivirus program.
Click the "Scan" tab or button, then click "Custom."
Uncheck all items in the list except for the drive letter assigned to the external drive.
Click "OK." Click "Scan" or "Scan Now" to run a virus scan on the hard drive.
Quarantine or remove any infections the virus scanner detects.
Click "Start." Input "cmd.exe" into the search field.
Press "Enter" to open Command Prompt. Input "chkdsk <drive>: /f /r" into Command Prompt.
Replace "<drive>" with the letter assigned to your external hard drive.
Press "Enter" to run CheckDisk on the drive.
CheckDisk will search for and repair detected errors or bad sectors.
Burn the files on the external hard drive to a set of DVDs or move the files to another drive, if possible.
If the IO device error reappears when attempting to move the files, disconnect the external hard drive from the computer.
Remove the power adapter from the drive.
Check the documentation included with the drive for instructions to take the drive apart.
If no instructions are available, contact the manufacturer for instructions or find out if disassembling the drive will void the drive's warranty.
Remove the screws securing the faceplate to the drive or from the edge of the enclosure. Insert the edge of a small, flathead screwdriver in between either side of the enclosure to wedge both sides apart.
Check the connections to the drive.
Confirm that the IDE or SATA interface is plugged into the back of the drive.
Reassemble the external hard drive, reconnect the power adapter and reconnect the drive to the PC.
Attempt to access the files on the drive.
If the IO device error reappears, return to Command Prompt. Input "format /fs:fat32 <drive>:" into the command-line prompt.
Replace "<drive>" with the letter assigned to the external hard drive.
Press "y" when the message "Proceed with Format (Y/N)?" appears.
The process will format the drive, erasing all data on the disk.
If the drive still fails to function after format, you will need to replace the drive.
Hope this helps
Buffalo... | Answered on Oct 04, 2018
hi Ivandbafc.
this is what i have found out.
If your hard drive is displaying any of these symptoms it is important to stop using your drive immediately, Ongoing use of a drive with these symptoms will result in irrecoverable damage being caused to the media.
  • Hard drive producing a clicking sound.
  • Hard drive producing a clunking sounds.
  • Hard drive making buzzing sounds.
  • Hard drive making a grinding sound.
  • Its best you try and save all data to another drive asap.
Buffalo... | Answered on Nov 27, 2017
Did you place any magnets or magnetic tools near the drive? if so your drive is busted and you need to take it to a software retrieval company to get the data back. it may be expensive
Buffalo... | Answered on Nov 21, 2017
use a new ethernet cable
Buffalo... | Answered on May 06, 2017
Wi-Fi connection can create problems for various reasons like incorrect browser settings, errors in cable connection, misplaced passwords or a modem requiring reset.
Go to Control Panel>Network Connections. What does it tell you there? It should have Wireless Internet Connection and either connected, disconnected or disabled.
Follow the given steps may be it will help you..
--check your web browser and activate the "Work Offline" option. To get this option, go to the "File" tab in your web browser and click the "Work Offline" option to uncheck it.
--Make sure your Ethernet cable is properly connected with your broadband modem and your wireless router. If this cable is loose at either connection point, you must tighten it before hoping to attain your Wi-Fi signal again.
--Press the "Reset" button that is located on the front face, top or rear of the broadband modem. This button allows your modem to re-initialize, and this may solve your problem once it boots back up.
--Enter your web address into your web browser and navigate to the page. A dialog box will appear that asks for a password, so enter the password from the manual.
--Log in using default username and password. You can now change the password for security purpose.
If you need any kind of technical assistance then you can contact support cell at http://www.vtechsquad.com
Buffalo... | Answered on Apr 03, 2017
Buffalo Technology AirStation WLA2-G54L 802.11g/b (WLA2G54L) Wireless Access Point Logo
Popular Tags
9 questions posted
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Ekse
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Buffalo Technology Computers & Internet
Most Popular Question
want chang pasword airstation ag54
  • Computers & Internet
