20 Most Recent Panasonic Look Video Cassette Recorder Ag-7750 Look Questions & Answers
Sir,
you will get it free from Panasonic website.
Panasonic AG... | Answered on Feb 08, 2016
MOST CAMERAS HAVE TO BE OFF WHEN TRYING TO DO THIS FUNCTION AND LET THE PC FIND THEM THEN TRANSFER TO PC READ THE MANUAL
Panasonic Video... | Answered on Jun 07, 2019
Unfortunately, Panasonic does not support the VDR-M70 with Windows 7 or 8. See the FAQ here: https://shop.panasonic.com/support-only/VDR-M70.html?t=manuals . The camcorder was released with drivers for Windows 98 (second edition), Me, 2000, and XP.
If you have Windows 7 Pro, you can check if your system supports a virtual computer environment. If you can load a virtual OS, enable virtualization in turn on/off Windows features. (Go to the Control Panel under Programs. Then click on the link. Scroll through the list to find the desired line and check the box.) The XP mode software is available here: https://www.microsoft.com/en-us/download/details.aspx?id=8002 . Install the program (including setting up the disc space needed). Then launch the OS and install the software and camcorder driver in the XP mode. Use the directions for installing the VDR-M70 with a computer from the manual, starting on page 130: ftp://ftp.panasonic.com/camcorder/om/vdr-m50pp_en_om.pdf . I haven't found an online source for the Panasonic software download for the VDC-M70. Panasonic's recent software is here: https://av.jpn.support.panasonic.com/support/global/cs/soft/download/ .
I hope this helps and I wish that I had better news for you.
(I did run XP mode on a Windows 7 Pro desktop computer with an Intel i5 chip and 8GB of memory. I put in a second hard disk to ensure sufficient space for the second OS. It was a convenient way to maintain support for some older hardware and software.)
Panasonic Video... | Answered on May 24, 2019
Sounds like the screen has either failed or the wiring to it has got a dry joint or become disconnected.
Panasonic Video... | Answered on May 19, 2019
Check your connections first. Usually a camera comes with software to allow transfer from camera to computer. If it has worked before, then there is a connection problem now. Windows media player supports many formats of video. Each format type is determined by the file extension, for example .mpg .mts .avi etc. If the camera records in an uncommon format, you may need to load a different CODEC (Compression/decompression program).
See here for all formats that windows media player supports:-
https://support.microsoft.com/en-gb/help/316992/file-types-supported-by-windows-media-player
The Panasonic PV-GS35 will let you record digital media to the mini DV cassette if the other video source has a DV input/output connection. Then you use the 4-pin to 4-pin Firewire DV cable, PV-DDC9 . This cable is available from Amazon, https://www.amazon.com/LETO-FireWire-Panasonic-Camcorder-PV-DDC9/dp/B00MLQVMSK , and other vendors. The digital camera doesn't have the S-video input needed to record from most other sources.
For information on the digital dubbing feature, see the manual starting on page 42. Panasonic has the manual on the product support page: https://shop.panasonic.com/support-only/PV-GS35.html . The current link to the manual is ftp://ftp.panasonic.com/camcorder/om/pv-gs19_en_om.pdf . See page 13 of the manual for the location of the DV port.
I hope this helps.
Panasonic Video... | Answered on May 11, 2019
Have you looked at the information and instructions contained within the manual ?
Panasonic Video... | Answered on Feb 22, 2019
.Prg files are database files. They could be associated with an indexing system for that camera. They are not in and of themselves a video file.
Panasonic Video... | Answered on Jan 28, 2019
Panasonic Look Video Cassette Recorder Ag-7750 Look Logo
3 questions posted
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
View Most Popular
AG Panasonic
  • AG Panasonic
Most Popular Question
ag 188
  • Video Cameras
