20 Most Recent Canon PowerShot S230 / IXUS 179 Digital Camera Questions & Answers
You can connect camera's memory card to computer, then download this picture recovery program which is outstanding among all picture recovery software.
http://www.001-software.com/picture-recovery/
Canon PowerShot... | Answered on Jan 12, 2015
Here you go... http://www.usa.canon.com/cusa/support/consumer/digital_cameras/other_powershot/powershot_sx130_is#DriversAndSoftware
Canon PowerShot... | Answered on Dec 08, 2014
You will need to install a noise filter on the positive line I believe it is, that goes to the radio.
The Source should have this.
Help and parts can be found on www.kijiji.com or .ca here in Canada.
Local stuff on that site.
Canon PowerShot... | Answered on May 21, 2014
Shoot, forgot to mention, take a coat hanger (one coated with plastic so as not to cause spark). Tape the ends if you wish. Push that down the input tube once the hose is removed from below.
Camera needs to be in gallery/photo browse mode. Worked for me.
Canon PowerShot... | Answered on Jan 04, 2011
This could be a stuck shutter, or a damaged LCD, or a bad backlight on the LCD display, or maybe a loose ribbon connector from the LCD display to the main board, it's hard to say.
I would run it by a camera repair shop, to see what they think, and how much they would charge to fix it.
You can try to spray some compressed air into the lens assembly to try to free any dirt or lint that's worked it's way into the assembly, and you can also try to gently bump the camera with the palm of a hand, to try and free up a jammed gear inside the lens assembly.
Other than that, the unit will have to be opened up and serviced.
Here's Canon's support site, and you might try to contact them:
http://www.usa.canon.com/cusa/consumer/standard_display/support
Good luck, and hope this helps.
Canon PowerShot... | Answered on Dec 12, 2010
This is a common problem with this camera.
It has been confirmed that the connecting parts of the internal wiring of the CCD used in affected products may become disconnected, especially if the affected products are stored or used in high-temperature and high-humidity environments. If this occurs, the signal is not output from the CCD normally in Shooting Mode, which may cause a distorted image or the absence of an image. This malfunction can be confirmed on the LCD monitor screen during shooting. The same malfunction also appears on the recorded image.
This camera is not covered under CCD advisory, however there are people who got it fixed without any charge. You need to call and complain. It would be worth a complain, as this is common problem even with Sony, however they never hesitate to replace or repair it at no cost.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
PS - Do accept the solution so that i could get the credit for my time.
Canon PowerShot... | Answered on Dec 08, 2010
Base from the description of your problem its clear that the issue here is with the LCD screen of the camera that is bad already and since this is already a 6 year old camera having it repair will worth the price of getting a new camera now, so I strongly suggest you just go get a new one.
Canon PowerShot... | Answered on Jun 14, 2010
It is known problem of ccd imager failure in Canon S230 camera and ccd imager chip will be replaced to have live view in camera mode.
Canon offers free of cost ccd imager chip replacement for this model, click Canon CCD Imager Advisory for details.
Thanks.
Canon PowerShot... | Answered on May 23, 2010
Skip this kind of transfer, save time by buying and using a card reader/writer. This way it is not necessary to have the need for any software on the computer. You can transfer any files from the card to the computer, and you can write to the card as well, if necessary. I recommend never to write to the card until you have transferred all files from the card to the hard drive. That is because by writing to the card, you may delete files.
Canon PowerShot... | Answered on Apr 15, 2010
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Canon PowerShot... | Answered on Feb 28, 2010
Please see the following info:
Canon PowerShot... | Answered on Jan 31, 2010
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Canon PowerShot... | Answered on Jan 17, 2010
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Canon PowerShot... | Answered on Dec 30, 2009
Hello and welcome to Fixya.
I'm afraid canon has no made any software for this camera for windows 7. The camera should show up in my computer or computer which you will find from start menu, most likely as a removeable storage device.
If the camera does not work right away when you plug it to a usb port, then the camera will not work with windows 7. Please buy a card reader, and use the cardreader to transfer your photos to the computer.
A card reader will cost you 5 to 30usd depending on what kind of a card reader you purchase. You can get a card reader from a local store, or from a camera dealer. Take your existing memory card with you to make sure you get the right kind of reader for your computer (USB) Any card reader will work with windows 7.
Let me know if you require anything else or if you have any questions.
Thanks,
Ekse
Canon PowerShot... | Answered on Dec 28, 2009
Canon PowerShot S230 / IXUS 179 Digital Camera Logo
Popular Tags
62 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
recover erased pictures from ixus 870
  • Cameras
