20 Most Recent Canon PowerShot S60 Digital Camera Questions & Answers
That means the The aperture or the shutter is damaged in the lens always staying closed not letting light thru, Needs repair probably around $145.00 great camera thou, Tony
Canon PowerShot... | Answered on Nov 09, 2013
I'm sorry for the difficulties you're experiencing in inserting the CF Card in the Memory Card slot on the Camera. Based on the information you have provided, it appears that the spring in the slot which gives pressure for the card is not working as expected. Please check the below picture and insert the card as shown in the figure even if the CF card eject button fully extend to resolve the issue. Close the door firmly after putting the Card in the slot.
Thanks for understanding. Please let me know if you require any clarifications.
Canon PowerShot... | Answered on Aug 13, 2011
This sounds like it might be a defective CCD imager, and is a known defect for your particular model camera.. If so, Canon should fix this for you for free if you live in the US, Canada, and a select few other countries. If you live outside the US, contact Canon support for your country to see if they'll still honor the advisory (some still will, especially if you stress you knowledge that this is a known defect of the camera). They may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please see this link for more info.
Canon PowerShot... | Answered on Jun 24, 2011
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Canon PowerShot... | Answered on Apr 05, 2011
Having gone over six months without a response, I assume my suggestion to use a card reader solved the problem.
Canon PowerShot... | Answered on Mar 31, 2011
It's possible it got bent out of shape. The viewfinders in pocket cameras are secondary to the rear screen, and some more recent models lack them entirely.
The reason why the screen is better in these cameras is because the main lens, and the viewfinder are separate by a few inches, so what you see in the view finder, and what the camera takes a picture of can vary by quite a bit.
Canon PowerShot... | Answered on Mar 03, 2011
Hi. In playback Mode, press Menu, select 'Erase all images', pressSet, select OK, press Set. An alternative is to Format the card, which alsore-organises the file system. Menu, Right Arrow, then (in the Setup Menu)Up/Down arrow buttons to select 'Format' and press the Set Button. Then use the Left/Rightarrow buttons to select 'OK' and press the Set Button. You can also format thecard in PC , by right clickingits icon in My Computer to bring up the option, but it is a good idea toformat again in the camera to ensure full compatibility. The manual can bedownloaded at:-
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man . Regards
Canon PowerShot... | Answered on Jan 21, 2011
Affected cameras with this problem include: A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Canon PowerShot... | Answered on Jan 09, 2011
i think acording my experiances the fault is in ur memory. please delete all ur older 4tos and then try ur cam. please delete them by a computer. then check it. if it still does not fix ya please get ur cam a ful service. thankyou!
Canon PowerShot... | Answered on Nov 13, 2010
Canon PowerShot... | Answered on Oct 24, 2010
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Canon PowerShot... | Answered on Oct 02, 2010
Affected cameras with this problem include: A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S230, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Canon PowerShot... | Answered on Aug 02, 2010
Canon PowerShot... | Answered on Jul 20, 2010
Press Menu Go to camera settings By moving the cursor go to factor settings Click and press OK.
Canon PowerShot... | Answered on Jul 19, 2010
If the camera is showing a black or distorted screen when set to photo, and photos that are taken with the black screen also show up black or distorted, then this would likely be a CCD imager failure, a common occurrence for your model camera.
If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Canon PowerShot... | Answered on May 31, 2010
How about brand new images just taken, are they also black? If so, this sounds like it might be a defective CCD imager. Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S230, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Canon PowerShot... | Answered on May 23, 2010
Canon PowerShot S60 Digital Camera Logo
69 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
clear memory card please
  • Cameras
