FixYa.com
NEC SuperScript 1800 Laser Printer
All Products > NEC > Printers
Problems with NEC SuperScript 1800 Laser Printer?
Troubleshooting and Support
Solved Problems for NEC SuperScript 1800 Laser Printer RSS Feed Post a New Problem
NEC SuperScript 1800 Laser driver to use...
I am looking for a driver for my NEC SuperScript 1800N to work with MS Vista
1 Solution
Can you advise me as to what the problem...
Hi Every time I try to print on my Superscript 1800 I get a 'Paper Jam' error message. Is this a readily repairable item...
1 Solution
scanning to my computer
What do I need in addition to my printer to be able to scan to my computer? Lorna
1 Solution
IBM 6400 MODEL 9
Customer claims the message 'end of forms' displays every time a 'file' is sent to printer even though there are forms...
1 Solution
HP 5110 All-In-One printer / Vista...
I have an HP 5110 all-in-one Series printer and a new HP desktop computer which has Windows Vista. When I try to connect...
2 Solutions
just for information
Can I download the installer of Minolta Dialta Di 1610?
1 Solution
Please advice a laser printer
Please advice a laser printer for printing semi gloss label at home, cheap and good, for A4 size sheet. Thank you for...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for NEC SuperScript 1800 Laser Printer RSS Feed Post a New Problem
Where to get parts for fuser assembly?
I found a gear inside the fuser assembly worn, and can not move the roller causing papers to jam. Can someone give me...
Post a Solution
pixma 1800 full ink absorber
How do i fix full ink absorber?
Post a Solution
NEC SuperScript 1800 Laser Printer Repair...
Does anyone have a NEC SuperScript 1800 Laser Printer Repair Manual?
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Technology (Detailed)Laser
Black Print Speed17 ppm
Max Resolution (BW)1200 x 1200 dpi
Technical Features
Form FactorDesktop
Connectivity TechnologyCable
Duplex PrintoutStandard
Monthly Duty Cycle999 and less (Low Output)
Language SimulationPCL 5E · PCL 6
Media
Media TypeTransparencies · Envelopes
Max Media SizeLegal (216 x 356 mm, 8.5 x 14")
Total Media Capacity1000 Sheets
Media Path TypeStraight
System Requirements
Operating SystemMicrosoft Windows 3.x
Warranty
Warranty1 Year
Dimensions
Depth17.34 in.
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
