NEC SuperScript 870 Laser Printer
Problems with NEC SuperScript 870 Laser Printer?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for NEC SuperScript 870 Laser Printer RSS Feed
Click here to get instant support from our best Experts!
View More Results for NEC SuperScript 870 Laser Printer
Questions and Unsolved Support Problems
Unsolved Problems for NEC SuperScript 870 Laser Printer RSS Feed
Answer
I have an NEC 870 that I have had for years. I just replaced the toner and imaging modules with new... (More)
Answer
My NEC 870 laser printer has paper jam. How can I fix it?
Answer
sometimes the paper jams and has tooth marks on it whn i forcefuuly pull it out
Answer
all the panel lights are on, I have checked for any paper jams, I have completely disconnected it... (More)
Answer
My NEC 870 has suddenly started printing pages with several horizontal lines running across the... (More)
Find a Manual
NEC SuperScript 870 Laser Printer Manuals & Guides
Tips & Tricks
(Post a New Tip)
Black lines on faxes or copies
Do you have black lines in your scanned or copied documents? The typical problem is ink, correction fluid or trash blocking the image sensor. Look at... written by buddymc
How can I print what appears on the screen completely?
Many web designers are conscious of the fact that some people will want hard copies of their web pages. For these sites, you can... written by mianaftab
Printers and scanners and copiers (OH MY!)
How do I fix the error on my printer scanner copier fax that says "yada yada yada you cant print anymore"? 99% of the time, you cant. You... written by fredtmccoyjr
Setting up Epson Stylus SX515w on a PC.
This guide will show you how to setup the Epson Stylus SX515w, without using the setup CD & USB cable. 1) Using the Control... written by TJ4722
how to get rid off paper jam errors in lexmark injet printers .
1. Turn the printer off and open the access cover. 2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to... written by Ajkill
How to maintain your ink-jet printer
In the printer market there have thousands difference brands and models ink-jet and laser-jet printer, how can we eleminate their trouble to the... written by swan34
How to reset drum message after replacement on brother printers
Does your brother printer or fax machine have bad printing such as dark blurry pages or your machines says replace drum then follow these... written by buddymc
How to clean the corona wire on Intellafax 2800,2810, 3800 machines
Does your brother printer or fax machine have bad printing such as very light print or spotty print. If you have these problems chances are you have a... written by buddymc
WikiManual
(Post a New Chapter)
Inkjets and Laser Priners, Inks, Toners,...
Using recycled ink cartridges in your ink-jet printer is never a more economical way to do colour printing, unless you are willing to become a master... by Soulvisitor
How to Refill and Reuse a Printer Cartridge
Printer ink is one of the most expensive things that you'll run into when you set up your home office. You start out taking dozens of pictures with... by wikihow
How to Cut Printing Costs on Inkjet Color Printer
With all of the color printing that people do nowadays, its hard to find ways to print inexpensively. There are ways to reduce printing costs on... by wikihow
How to Check if Your Printer Has Run out of Ink
Have you ever wondered if your printer has run out of a colour? Here's a simple way to check. Steps: 1. Go into Microsoft Word. 2. Create four small... by wikihow
Lexmark All-in-One x3350
'Resetting' your Lexmark x3350 All-in-One So I tried using my Lexmark today... the power button is constantly on, and it won't do anything, My... by TTonyTigger
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for NEC SuperScript 870 Laser Printer
Nationwide | 8008369287 | Website
Celebrating 14 Years Of Outstanding Printer Repair And... Read More
Featured Listing
Nationwide | 9185835483 | Website
Elite printer Services, Inc. is a full service HP & L... Read More
Featured Listing
Nationwide | 972-907-9771 | Website
Printronix, IBM, Tally, Genicom, TallyGenicom, Dig... Read More
Featured Listing
Nationwide | 800-786-0288 | Website
Accram is now one of the largest nation wide mai... Read More
Ratings for the NEC SuperScript 870 Laser Printer
Owners Recommend
out of 1
Reliability
Ease of use
Value for Money
Rate and Review the NEC SuperScript 870 Laser Printer
Write a review:
Rate this product:
Would you recommend the SuperScript 870 Laser Printer to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for NEC SuperScript 870 Laser Printer
Key Features
Platform
PC
Type
Workgroup
Technology (Detailed)
Laser
Black Print Speed
8 ppm
Output Type
Monochrome Printer
Max Resolution (BW)
600 x 600 dpi
Technical Features
Form Factor
Desktop
Monthly Duty Cycle
1,000 - 9,999 (Individual)
Language Simulation
PCL 4.5 · Adobe PrintGear
Media
Media Type
Transparencies · Plain Paper · Envelopes · Labels
Max Media Size
Legal (216 x 356 mm, 8.5 x 14")
Total Media Capacity
150 Sheets
System Requirements
Operating System
Microsoft Windows 3.x · Microsoft DOS · Microsoft Windows NT
Warranty
Warranty
2 Years
Dimensions
Depth
11.47 in.
Height
10.52 in.
Width
15.52 in.
Weight
17.64 lb.
NEC Contact Information
Main support number1-800-338-9549
Describe your problem:
Top Printers Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
