FixYa.com
NEC MobilePro 900 Handheld
All Products > NEC > PDAs
Problems with NEC MobilePro 900 Handheld?
Troubleshooting and Support
Solved Problems for NEC MobilePro 900 Handheld RSS Feed Post a New Problem
critical error 678
I have a critical error 678 in my nec mobilepro 900 when connect the usb to my pc. thank you for help to me
3 Solutions
setting my dialup
i need setup for dialup or where is the setup wizard
1 Solution
mobilepro 900c won't sync
Hi, Guys,I purchased my mobilepro 900c on EBay. It seems to work just fine. On my PC (working under XP) I have installed...
1 Solution
Nec Mobile Pro 900c stuck
hi guyz....i just got a nec mobile pro 900c from my brother...but when I turned it on all I see is a the the blue screen...
1 Solution
My external microphone jack and USB's...
My laptop is Toshiba Satellite P15-S420 It is two problems: First: I tried to use canon scaner thru USB port, it...
2 Solutions
Ctrl+ALT+Del
Ctrl+ALT+Del does not launch Task Manager on my MobilePro 900, why?
2 Solutions
NEC MobilePro 900 lines in display
I purchased a used NEC MobilePro and, after trying it out by playing a game of Solitaire on it, vertical lines appeared,...
2 Solutions
View All
Unsolved Support Problems
Unsolved Problems for NEC MobilePro 900 Handheld RSS Feed Post a New Problem
Mobilepro sync problem
Were you ever able to fix problem?
Post a Solution
what wireless/wifi cards are compatible...
I bought a used NEC MobilePro 900 and I love it, but am looking for a wireless/wifi card that is compatible, and has the...
Post a Solution
NEC 900c System freeze when inserting...
MY NEC 900c Handheld will freeze up almost immediatly when I insert the WPC11 version 3 WIFI card. I installed the...
Post a Solution
Four keys quit working
6,Y, H, N keys suddenly quit working. What is the best solution to this problem?
Post a Solution
nec 900
can i run windows mobile 5 on this, and if so , where do i get it and what do i have to do, thanks
Post a Solution
Dead Mobilepro 900 after bootloader...
After using some advice from the internet on how to fix my Pocketword problems by upgrading the bootloader, I now have a...
Post a Solution
nec mobilepro 900c wifi card
I have a 900c and RoamAbout wifi card, but no driver, and cannot find a driver. How can I get this card to work in this...
Post a Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Operating SystemProprietary
Installed Memory64 MB
Input MethodKeyboard · Touch Screen
Technical Features
Processor TypeIntel XScale PXA250
Processor Speed400 MHz
Interface TypeInfrared · Serial · USB
Expansion SlotCompactFlash (CF) Type II Slot
Display
Display TechnologyColor
Color Depth16-bit (64K Colors)
Screen Size (Diagonal)8.1 in.
Screen Resolution640 x 240
Multimedia
Audio OutputHeadphone Jack
Voice RecorderWith Voice Recorder
Communication
Wireless CapabilitiesInfrared irDA · Built-in Modem
Modem Speed56 Kbps
Battery
Battery TypeProprietary Lithium
Dimensions
Depth5.05 in.
Height1.19 in.
Width9.69 in.
Weight28.8 oz.
Warranty
Warranty (List)1 Year
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
