FixYa.com
OEM Systems Power Supply
All Products > OEM Systems > System Power Supplies
Problems with OEM Systems Power Supply?
Search inside OEM Systems Power Supply Knowledgebase
Troubleshooting and Support
Solved Problems for OEM Systems Power Supply RSS Feed Post a New Problem
screaming fan
hi, hope u can help. i have an hp compaq d350 with a screaming fan. it sounds like some sort of aircraft taking off when...
2 Solutions
Computer acting weird
Lost my entire desktop have to go to New Task by pressing alt, Cntrl, Delete. and go to browse to access internet , may...
1 Solution
computer doesn't switch on!
hi, my advent computer will not switch on anymore... i've checked cables fuses etc and changed the power supply but this...
1 Solution
ubs plug
I have a Systemax Tiger Pentium 4-2.4GHz computer and I can not find the UBS plugin. Can you help me ? Thank you Frank
1 Solution
Looking for ac power adapter
I bought an Advueu LCD tv a couple of years ago. Something tore up on it and I am thinking it might be the power...
1 Solution
Issue with a In Shin Power Supply
I took out the internal components of my boys computer it is the MSI Motherboard part # 2516512 it had a 90 watt power...
1 Solution
Ultra X3 800 watt power supply
Doesn't power up when turned on (at the main switch) does the mobo have to be connected to the ps before it will turn...
1 Solution
View All
Tips & Tricks
Post a New Tip
OEM Systems Contact Information
Main support number(775) 355-0405
Support FAX(775) 355-0646
Email supportInfo@oemsystems.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
