20 Most Recent American Weigh Scales Aws Chrome 1kg Pocket Jewelry Lab Scale 1000g X 0.1g Questions & Answers
What model? Could be the battery need to be changed.
at
http://www.tobaccogeneral.com/accur8-355-mnf.htm
tobacco is selling out their accura8
American Weigh... | Answered on Oct 29, 2017
But a new scope. Having the crosshair reseated will cost you more than getting a new BSA scope.
Science &... | Answered on Apr 03, 2018
Manuals are available from PHC. Email service@us.phchd.com or call Technical Support at 800-858-8442 ext. 48299.
Check the fuses located on both sides of the mains connection in the back of the autoclave. One of them has blown. If both check ok, then check the connection tho the mains. You may have a faulty ground. If you are not comfortable doing this, contact Eschmann at tel:+44 (0)1903 753322
Fax: +44 (0)1903 875789
info@eschmann.co.uk
If you're clever with electronics and can solder, consider an LED replacement. Do you have any data on the voltage, current, or lumen rating of the bulb?
Science &... | Answered on Mar 25, 2018
Choosing the right laboratory for conducting various tests and analyses can be a tricky affair. If there is any discrepancy in readings, it can be cause quote a stir. Thus, it is imperative that the staff operating the equipment of the laboratory must be expertly trained. The equipment itself must be top notch in quality. LiveScanLabs has managed to meet all this criteria. They have centers in Hialeah, Hollywood, Fort Lauderdale, Pembroke Park and Pembroke Pines. They conduct Fingerprint Analysis, Fingerprint Testing, **** Analysis, **** Testing, DNA Analysis, DNA Testing and regular health tests as well. Visit their website at www.livescanlabs.com.
Science &... | Answered on Mar 03, 2018
Are you sure that the lid safety interlock switch isn't damaged/dirty? If the centrifuge can't detect that the lid is closed it will never start. Sometime it just needs an extra push down on the lid.
Science &... | Answered on Jan 17, 2018
It sounds like either the bulb is loose or the connection between the bulb socket and a wire is loose. To check both, Loosen the screw knob on the underside of microscope and open the panel to expose the bulb. Use a small screwdriver to loosen the screws holding (the two screws closest to the bulb) the prongs of the halogen bulb. Note that the prongs of the bulb are held in place by small brass plates which shift slightly when the screws are loosened. Remove the old bulb. Important: Do not touch the new halogen bulb with bare hands. Wear gloves or hold the bulb using tissue or lens paper. Body oils may damage the halogen bulb. Insert prongs of replacement bulb into top of socket (above the brass plate) and tighten screws slightly. (The brass plates will move up to hold the prongs in place.) Close door and hand tighten the thumbscrew knob.
If this does not work, contact Premier for assistance: Premiere® Microscope Service, 7241 Gabe Court, Manassas, VA 20109 (703) 330-1413
Science &... | Answered on Jan 15, 2018
American Weigh Scales Aws Chrome 1kg Pocket Jewelry Lab Scale 1000g X 0.1g Logo
4 questions posted
Top American Weigh Scales Science & Laboratory Experts
ray gallant
Andrew Taylor
Andrew Taylor
S J Parkin
S J Parkin
Are you an American Weigh Scales Science and Laboratory Expert? Answer questions, earn points and help others
View Most Popular
  • American Weigh Scales Science & Laboratory
Most Popular Question
accura8 scale wont show calibration mode
  • Science & Laboratory
