I am unable to fully download the software and so cannot hot sinc with my laptop. I had a Zaire 31...
(More)
I am unable to fully download the software and so cannot hot sinc with my laptop. I had a Zaire 31 which worke fine until it "died". I tried to replace it with a Palm m515 but neither the CD that came with it, or the downloaded version from the net, allow me to hot sinc.
when I hot sync, the address book doesn't synchronize. I also am not able to access my palm on the...
(More)
when I hot sync, the address book doesn't synchronize. I also am not able to access my palm on the desktop to work from the computer. I keep getting an error message that says that "Error; failed to open address book database."
I am having troubles syncing with my Palm Pilot M515 , it used to sync but does not now... Can...
(More)
I am having troubles syncing with my Palm Pilot M515 , it used to sync but does not now... Can anyone help me, I have tried everything Russ Campbell
I have the palm m515 unit ( not a phone ) and until recently have had no problem. When I try to...
(More)
I have the palm m515 unit ( not a phone ) and until recently have had no problem. When I try to hotsync my PC (XP) says "Error:failed to open address book database" one report I read said I have too many addresses delete some then try again. I really don't want to delete any and want to add more (1600) The handheld says I've only used 5% of the capacity....can you help me? my phone number in case is 951 255 0010 .............thank you
After hot sync, Install To Card synchronization failed, message is given in hot synch log. Program...
(More)
After hot sync, Install To Card synchronization failed, message is given in hot synch log. Program is not downloaded to pda. This is a palm m515 and I have a 2 GB SD card
Your battery has been depleted past a chargable state. This is a due to a bad design in the phone that doesn't monitor the battery power state well...
written by PCTServices
select start ---- select settings ------- select connection----- select connections Now Select Add a new modem connection Connection name Give any...
written by billa vimal
I write this tip for Palm Pda's but it is valid for many other brands of pda's and phones. First things to try is a normal reset and then a hard...
written by Ekse
Lock code:
1. 5 digits, Used to prevent unauthorized access to certain functions on the phone
2. Where: Tools > Settings > Security >...
written by Shilon
Hi, Got this great instructions from - www.rapidrepair.com. Tools required: Small Phillips Screw Driver Small Flathead or exacto razor Safe Open Tool ...
written by merryAnn
We connect to your computer over the Internet to qui... Read More
We connect to your computer over the Internet to quickly repair your PC. Call Toll Free (877) 729-0812 for a Free Quote. Professional support with certified techs to make your computer run like new again.
Send your laptop to us and we will diagnose the pro... Read More
Send your laptop to us and we will diagnose the problem free of charge! We repair all over the U.S.A.! Our master certified technicians will run tests to determine the problem and will call you with a quote within 48 hours! Our labor rates are low and very fair. We are proud to be an accredited Better Business Bureau Member with an A+ rating.
Zkarlo.com provides discount and used laptop parts for... Read More
Zkarlo.com provides discount and used laptop parts for thousands of models. We offer Toshiba, Sony, HP, Compaq, eMachines & Gateway, Dell and more!
Choose from thousands of parts, including: LCD Screens, Motherboards, Keyboards, AC Power Supplies, Cases, Hinges, Drives, Batteries and more!
We fix and repair laptop motherboard no video, no pow... Read More
We fix and repair laptop motherboard no video, no power, dc jack, lcd inverter, back light, shorted ac adapter issues down to component level. Cincinnati, Hamilton 45011, West Chester 45069, Fairfield 45246 Ohio OH Laptop PC Computer repair service, Projection bulb TV LCD, Plasma, HDTV, projector repair. Projection bulb TV, LCD TV, Plasma, project
We offer computer consulting services, hardware and... Read More
We offer computer consulting services, hardware and software technical support. We specialize in networking design, installation, and support. No job is too big or too small. For the homeowner we offer a reduced rate. We also build our own pc?s and sell hardware and software
Affordable Laptop and Desktop Repair. We spe... Read More
Affordable Laptop and Desktop Repair. We specialize in Laptop LCD Screen repair, Laptop DC Jack Repairs, Laptop Motherboard repairs, Data Recovery. We offer on-site service, local walk in service where available and mail in services.
