20 Most Recent Palm Zire 71 Handheld Questions & Answers
You can try to leave it for a few hours then charge it again. Or you can replace the batteries. I also have the same problem but after the reset, everything worked fine
Palm Zire 71... | Answered on May 08, 2019
You aren't going to find that information anywhere. My advice is to either return it to Palm, or buy a spare one. There is one for $4 that needs a charger.
Palm Zire 71 Repair
Palm Zire 71 Take Apart Directions - DirectFix
www.directfix.com/category/_ZIRE71_TAKE.html
iPhone Replacement Parts? We offer iphone parts for cracked iphone screens. DirectFix offers iphone screen replacement parts, iphone repair parts & iphone ...
Palm Repairs ' palmdr.com
www.palmdr.com/pda-repair/palm Tungsten T, T2 and T3 Repair Form. Zire Series Models Zire 72 Choose either our Repair Form or Express Repair Service Zire 31 Repair Form Zire 71, Zire 21, ...
Zire Series : PalmDR.com, PDA Repair Done Right!
www.palmdr.com > Home > Accessories Products 1 - 12 of 27 - PalmDR.com : Zire Series - PDA Units Accessories Printers Repair ... Perfect fit screen protectors for your Palm Zire 71 or Zire 72 PDA unit.
Palm Zire 71 PDA for Parts or Repair • $4.00 - PicClick
https://picclick.com/Palm-Zire-71-PDA-for-Parts-or-Repair-192159832687.html Up for auction is a for Parts or Repair Palm Zire 71 PDA for Parts or Repair This is in excellent physical condition but I do not have the charger 192159832687.
Palm Zire 71 PDA for Parts or Repair 805931008343 ' eBay
www.ebay.com > ... > Gadgets & Other Electronics > PDAs > See more Palm 71
Rating: 4.5 - ‎80 reviews
This is sold as is for parts or repair. This is in excellent physical condition but I do not have the charger to test. I do not know if the battery is good or bad or if it is ...
Palm Zire 71 Blue PDA Organizer - Bad Battery - For Parts/Repair
www.ebay.ca > Consumer Electronics > Gadgets & Other Electronics > PDAs Palm Zire 71 Blue PDA Organizer - Bad Battery - For Parts/Repair in Consumer Electronics, Gadgets & Other Electronics, PDAs ' eBay.
Palm Zire 71... | Answered on Jul 25, 2017
I have the same problem and discovered that the right side of the screen had "spread". When I draw a line from the left to the right using Note Pad, the line ends up about 1/4 inch above the stylus. What I had to do is touch the stylus about 1/8th of an inch above the center of the digitizer target on the right side.
Palm Zire 71... | Answered on Jan 19, 2017
You find a fix to that problem, and the (Palm) world will beat a path to your door. HP, Palm's new owner, has attempted a fix for Win7, but Win8/8.1 may become the impossible hurdle.
Palm Zire 71... | Answered on Jun 20, 2014
This "question" is a feeble attempt at spam. But I thank you for the easy points.
Palm Zire 71... | Answered on Oct 08, 2013
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Palm Zire 71... | Answered on Jan 28, 2013
u need to refix that rubber.......
Palm Zire 71... | Answered on Nov 04, 2012
Check and see if you can download a "mediaimpressions" driver. I have found it is great for downloading photos from any device. GOOD LUCK
Palm Zire 71... | Answered on Jul 02, 2012
You need to reinstall the software.
Palm Zire 71... | Answered on Jul 05, 2011
Hi jmtrego Listen you need to go into menu and then go into the connections. Then you need to check active syn on the zire . Next you check the pc connections to the zire
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Palm Zire 71... | Answered on Jan 25, 2011
ok here is a possible solution for your palm Zire 31. Screen calibration may be failing because its alignment got corrupted. try taping not exactly where you should. tap just below or slightly to the left (right). you will get through that loop.
Palm Zire 71... | Answered on Oct 30, 2010
Are you upgrading from a previous Palm that synched using a serial cable? Even if not, you may have inadvertently set it up for the wrong interface. On your desktop computer, Right-Click on the Hot Sync icon in the system tray (next to the time) and verify that there is a checkmark next to Local Serial on top of the popup menu.
Also, verify the HotSync app on your Palm. Local should be selected above the logo and cradle/cable should be selected below the logo.
Double check your cables make sure they're connected properly, including the power for your Palm. Make sure the Palm is seated properly in the cradle and the Green light is on solid.
Please check the links bellow and read the articles therein related to your problem:-
http://www.companionlink.com/support/em/em0022.html
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,t=ooccase,case=obj(30421)
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Palm Zire 71... | Answered on Sep 29, 2010
the screen needs calibration. below are the instruction on how to calibrate the screen. The Digitizer Preferences screen opens the digitizer calibration screen. This is the same screen that appears when you start your handheld for the first time. You can recalibrate your screen after a hard reset or if your digitizer drifts. You may need to repeat this process a few times until the calibration registers. To calibrate your handheld screen: 1. From the General Preferences list, select Digitizer. 2. Tap the targets as indicated on the screen as precisely as possible.
TIP You can also press Left, Right, Up, and Down on the navigator to highlight a Preferences screen name and then press Select on the navigator to open that Preferences screen.
Palm Zire 71... | Answered on Aug 04, 2010
it's in spanish. it means, literaly, Pay gym ÿÿÿÿ eg ÿÿÿ QA C ~ Ă Ă Ă ˛ C ÿÿÿÿ Australia Day
Palm Zire 71... | Answered on Jul 02, 2010
Have you tried to Reset the Device? If not, try it and let me know the result.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Palm Zire 71... | Answered on Feb 12, 2010
Palm Zire 71 Handheld Logo
Popular Tags
117 questions posted
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Zire Palm
  • Zire Palm
Most Popular Question
zire 71 screen not sense stylus input
  • Computers & Internet
