20 Most Recent
Kodak MAX Water & Sport One-Time Use Camera Questions & Answers
Kodak Easyshare Z740 turns off while trying to take pictures constantly
There are a few possible reasons why your Kodak Easyshare Z740 camera might be turning off while you are trying to take pictures:
- The battery might be low or dead. Try replacing the battery with a fully charged one to see if this fixes the issue.
- There might be a problem with the camera's power supply. Try cleaning the battery contacts and charging the battery to see if this fixes the issue.
- There might be a problem with the camera's firmware. Try updating the firmware to see if this fixes the issue.
- There might be a problem with the camera's hardware. If the camera is still under warranty, you should contact Kodak for service. If the camera is not under warranty, you may need to take it to a repair shop to have it fixed.
I hope this helps! Let me know if you have any other questions.
My kodak easyshare m883 camera turns on lets me change the time and date then cuts out
please ensure that the battery isn't past it's expiration date- even if it's not been used before, an expiration m. And please ensure that the sd card does not have more data stored than was built for the camera to handle. If so, please transfer some data off of the sd card and then attempt to set the date on your camera again.
Thank you.
The screen and pictures are black even in light
Please make sure that your camera doesn't have a black cover or tax over the lends. This would block any images from being stored whenever you attempt to take a picture. In other words, the camera wouldn't be able "to see". If you can't find any cover, please check that you've properly inserted an SD card for the camera to use and then switch modes (ie action, night time etc) until you see the area that you're attempting to capture come on the camera screen. Otherwise, you might need to get the camera checked at a store like BH Photo and video.
Thank you.
