20 Most Recent
SanDisk Adapter An 8 Gb Micro Sd Hc Memory Card 8gb Questions & Answers
SanDisk Memory Cards & USB Flash Drives Data error cyclic redundancy check
Try this, go to start, all programs, accessories, now RT click on command prompt and pick run as Admin.Now type chkdsk G: G is what ever the card shows as, in your PC, so if your card shows as E: then use E.When it's done you will see C:\windows\system 32Wait it might take a while.Now type DiskPartwait, you will see a few lines one says microsoft and when it's ready you will see it say DiskPart> rescanSo after DISKPART> type rescanNow try and delete everything from the card and do a quick format.If this didn't work, you'll have to shell out 7.00 for a new card.
How do i download from my sandisk card to my computor
Insert the card into a compatible card reader, either built-in to the computer or attached via USB/FireWire. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
Inaccessible memory card
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card,
then remove the memory card from the camera and insert it into an USB memory
card reader. Connect this USB memory card reader and memory card into the USB
port of your working computer. Your computer will see this as an USB Mass
Storage Device or an external storage device; you can then open the folder on the
memory card and copy the photos to your computer.
Memory card reader is a handy device and is inexpensive. You
can copy photos from other cameras and you can also download photos off your
memory card to someone else's computer without the need of installing any
programs.
I have my SanDisk plugged
You need to use the supplied Sansa Media Converter program to convert your photos (and videos) to a format the Sansa can handle. If you don't have the SMC, you can download the Windows version from http://www.megaupload.com/?d=3IPZO6Q0
Just bought a used Pentax Optio 750Z online. Am
Is it a SDHC card? SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
You could try formatting the card. There is a function in the camera menus to do this. If it won't format then it may simply be too high capacity. It is often difficult to find out the maximum capacity a camera will use, as today's memory cards are much larger that those available when the manuals for even recent cameras were written.
I JUST GOT A NEW
I do not see your camera model number or brand info in question but I think your camera is bit old one so that is why does not support such big memory card because camera hardware does not support it.
Use 2GB memory card in camera that will be accepted/ supported by camera hardware.
Thanks.
