FixYa.com
Ricoh Aficio IS01 Flatbed Scanner
All Products > Ricoh > Scanners
Problems with Ricoh Aficio IS01 Flatbed Scanner?
Troubleshooting and Support
Solved Problems for Ricoh Aficio IS01 Flatbed Scanner RSS Feed Post a New Problem
Image is Streched when scanned
This is an ongoing problem experienced after the scanner has been used quite a it. When scanning documents through the...
2 Solutions
How to Clean a Scanner?
1 Solution
How to Connect a Parallel Scanner to a...
How to Connect a Parallel Scanner to a Computer?
1 Solution
The file size of my saved image is too...
The file size of my saved image is too big, i cant work with it, is there anything i can do?
1 Solution
How to test a scanner for color...
How to test a scanner for color registration?
1 Solution
How can i Use a Scanner to Capture Text?
2 Solutions
Which file format is proper to save the...
Which file format is proper to save the scanned image?
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Ricoh Aficio IS01 Flatbed Scanner RSS Feed Post a New Problem
Timing out when the scanner drives are...
During bios set up it seeks for devices. While seeking device it times out.
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC
TypeFlatbed Scanner
InterfaceSCSI-2 Fast (8-bit)
Optical Resolution400 dpi
Max. Resolution (Hardware)400 x 400 dpi
Max. Gray Depth8-Bit (256 Gray Levels)
Technical Features
Form FactorDesktop
Media
Supported Media TypePlain Paper
Media Loading MethodAutoload
Max. Supported Media SizeA3 (297 x 420 mm)
System Requirements
Operating SystemMicrosoft Windows 95
Dimensions
Depth19.7 in.
Height11.82 in.
Width21.67 in.
Weight61.74 lb.
Ricoh Contact Information
Main support number800-327-8349 / 800-637-4264
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
