FixYa.com
Ricoh IS420 Flatbed Scanner
All Products > Ricoh > Scanners
Problems with Ricoh IS420 Flatbed Scanner?
Troubleshooting and Support
Solved Problems for Ricoh IS420 Flatbed Scanner RSS Feed Post a New Problem
How to test a scanner for color...
How to test a scanner for color registration?
1 Solution
Which file format is proper to save the...
Which file format is proper to save the scanned image?
1 Solution
How to Connect a Parallel Scanner to a...
How to Connect a Parallel Scanner to a Computer?
1 Solution
My CanoScan D1230U has stopped working
Resentley fter years of use my CanoScan D1230U has stopped working. Everyting was connected properley but it still...
1 Solution
scanner instruction
I would like the instruction for lexmark x 4.270
1 Solution
How can I download Acer SanPrisa 640P...
Hello There! I want to download the above subjected driver for acer scanner of ScanPrisa 640P. as I lost its...
1 Solution
Umax Astra 2500 XP Driver (Free)
I am getting problem How to download free scanner driver of UMAx Astra 2500 XP Driver . Please guide me . Thanks
4 Solutions
View All
Unsolved Support Problems
Unsolved Problems for Ricoh IS420 Flatbed Scanner RSS Feed Post a New Problem
richo is420 scanner
I need 2 clutches one for paper pickup and one for tray lift. I also need the big roller. can you help with part...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC
TypeFlatbed Scanner
InterfaceSCSI-2 Fast (8-bit)
Optical Resolution800 dpi
Max. Resolution (Hardware)800 x 800 dpi
Max. Gray Depth8-Bit (256 Gray Levels)
Technical Features
Form FactorDesktop
Input TypeMonochrome
Media
Supported Media TypePlain Paper
Media Loading MethodAutoload
Max. Supported Media SizeLegal (216 x 356 mm)
System Requirements
Operating SystemMicrosoft Windows 3.x · IBM OS/2 · Microsoft Windows NT
Dimensions
Depth26.4 in.
Height11.11 in.
Width17.73 in.
Weight55.13 lb.
Ricoh Contact Information
Main support number800-327-8349 / 800-637-4264
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
