FixYa.com
Ricoh IS 450SE Flatbed Scanner
All Products > Ricoh > Scanners
Problems with Ricoh IS 450SE Flatbed Scanner?
Search inside Ricoh IS 450SE Flatbed Scanner Knowledgebase
Troubleshooting and Support
Solved Problems for Ricoh IS 450SE Flatbed Scanner RSS Feed Post a New Problem
ricoh is 45se scanner squeaking loudly
Just wanted to see if you could give me some insight on this. The squeaking usually occurs after say 50 pages are sent...
1 Solution
where can i get instructions for the...
where can I download instructions for my microtek scanmaker 5600
1 Solution
scanner installation in vista OS
i m using color flatbed scanner  of acer i m not able to install the mira CD in windows vista home basic what is...
1 Solution
How to add more pages while scanning with...
Is is to possible to insert / add-on more pages, while doing scanning with Umax Astra 5600 Thanks & regards
2 Solutions
scanner
dont know how to position document during scanning. every position i try cuts off some of the document
1 Solution
How to test a scanner for color...
How to test a scanner for color registration?
1 Solution
I unhooked by scanner ro rearrange some...
I unhooked by scanner ro rearrange some equipment and forgot how it was connected. I think it should be as follows:...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC
TypeFlatbed Scanner
InterfaceSCSI-2 Fast (8-bit)
Optical Resolution400 dpi
Max. Resolution (Hardware)400 x 400 dpi
Max. Gray Depth8-Bit (256 Gray Levels)
Technical Features
Form FactorDesktop
Input TypeMonochrome
Media
Supported Media TypePlain Paper
Media Loading MethodAutoload
Max. Supported Media SizeANSI B (Ledger) (279 x 432 mm)
Warranty
Warranty1 Year
Ricoh Contact Information
Main support number800-327-8349 / 800-637-4264
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
