FixYa.com
Ricoh IS450DE Flatbed Scanner
All Products > Ricoh > Scanners
Problems with Ricoh IS450DE Flatbed Scanner?
Troubleshooting and Support
Solved Problems for Ricoh IS450DE Flatbed Scanner RSS Feed Post a New Problem
Ricoh IS450DE Scanner
My scanner is printing a dark line down the middle of each print out. What could be the problme
1 Solution
Scsi Interfase card
Which is the fast scsi 2 interfase card to use with the IS450DE. Please, we need to know trademark and model. Thanks....
1 Solution
Twain driver not WIA on XP
We recently upgraded a PC used for high speed scanning from 98 to XP. Also included in the upgrade was Paper Port...
4 Solutions
How to Clean a Scanner?
1 Solution
How to test a scanner for color...
How to test a scanner for color registration?
1 Solution
scanner
dont know how to position document during scanning. every position i try cuts off some of the document
1 Solution
How can I download Acer SanPrisa 640P...
Hello There! I want to download the above subjected driver for acer scanner of ScanPrisa 640P. as I lost its...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Ricoh IS450DE Flatbed Scanner RSS Feed Post a New Problem
reduced printouts using the flatbed mode
when I scan using the flatbed as opposed to the document feeder for scanning, the print size is reduced.
Post a Solution
Scanner on a hp750 psc
my hp 750psc has started to work only now and then, I keep getting a twain driver error saying missing or not installed,...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC
TypeFlatbed Scanner
InterfaceSCSI-2 Fast (8-bit)
Optical Resolution200 dpi
Max. Resolution (Hardware)200 x 400 dpi
Max. Gray Depth8-Bit (256 Gray Levels)
Technical Features
Form FactorStationary
Input TypeMonochrome
Media
Media Loading MethodAutoload
Max. Supported Media SizeANSI B (Ledger) (279 x 432 mm)
Dimensions
Depth26.99 in.
Height4.37 in.
Width18.79 in.
Weight55.13 lb.
Ricoh Contact Information
Main support number800-327-8349 / 800-637-4264
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
