FixYa.com
Ricoh IS 330DC Flatbed Scanner
All Products > Ricoh > Scanners
Problems with Ricoh IS 330DC Flatbed Scanner?
Troubleshooting and Support
Solved Problems for Ricoh IS 330DC Flatbed Scanner RSS Feed Post a New Problem
Adobe interface issues
Our Ricoh IS330DC is not scanning as clearly as we know it can. When using Windows and direct scanning the image is very...
1 Solution
Document feeder will not Operate
When attempting to use the document feeder by selecting ADF in the Desktop Binder V2 software I get the following error...
2 Solutions
Scan lines
Scans have lines going through it. How do I fix?
1 Solution
scanner installation in vista OS
i m using color flatbed scanner  of acer i m not able to install the mira CD in windows vista home basic what is...
1 Solution
Lexmark series 2480 won't scan
Help! I have no technical abilites! I have used the disk to instal the software and can print fine, but have just tried...
1 Solution
Laptop Windows Vista
cannot scan to Laptop
1 Solution
Scan to OCR
I have trouble with the brother control centre, if i pic option scan to ocr, it says i need to download the software?...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC
TypeFlatbed Scanner
InterfaceSCSI
Optical Resolution600 dpi
Max. Resolution (Hardware)600 x 600 dpi
Technical Features
Form FactorDesktop
Input TypeColor
Media
Media Loading MethodManual Load · Autoload
Max. Supported Media SizeANSI B (Ledger) (279 x 432 mm)
Dimensions
Depth21.51 in.
Height10.44 in.
Width23.25 in.
Weight61.74 lb.
Ricoh Contact Information
Main support number800-327-8349 / 800-637-4264
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
