20 Most Recent Ricoh CL3000E Laser Printer Questions & Answers
what do you mean changed color, please elaborate so i can help you out, in similar scenario it could be a sliping clutch that controls the developing unit causing the respective color to disengage while working on, M, C Y, K pls identify which is which, if you can try one of each color independently as a diuagnostic then youcan start from there which color is malfunctioning,remember the combination of each color depends upon each other color, thus maybe is the reason you can see a sudden changed of color
Ricoh CL3000E... | Answered on Jul 27, 2016
Hi yes you can fix it yourself it is just a warning that says the black pcu is almost warn out , but if the quality is still good you can clear the message is the sp modes by holding down online and escape whilst switching on the machine , under the menu "engine " is a sub menu called data log enter it and execute pm counter reset
hope this helps
Ricoh CL3000E... | Answered on May 15, 2016
Could be drum /fuser/ roller will need to stop the copying in different place and look we're line shows up that will help in finding what causing line
Ricoh CL3000E... | Answered on Jul 10, 2014
not a solution - but a problem... i emptied the toner waste bottle in my MPW2400 and a new error message appears...says there is no toner and it keeps dumping toner from the new cartridge until it is coming out of every orifice of the machine. What is that about?
Ricoh CL3000E... | Answered on Nov 16, 2012
Hello
From the control panel: MENU - MAINTENANCE - MAINT. RESET - TRANSFER BELT - #. The procedure is in the operators manual.
good luck and do rate the solution if helped.
Ricoh CL3000E... | Answered on Apr 20, 2011
Ricoh CL3000 Laser, replace waste toner displar unit will not print, waste toner cartrige is empty.printer will not print? How do I reset unit?
Ricoh CL3000E... | Answered on May 27, 2010
1. Lift the original feed unit.
2. Lift the upper unit.
3. Right upper cover
4. Right cover [
5. Loosen the leaf spring and lift it.
6. Toner overflow sensor
7. Toner collection bottle
Once you have it out jsut dump it out (carefully) remove the sensor on the bottle and wipe clean reinstall the sensor re install the bottle and you should be good to go
Ricoh CL3000E... | Answered on Apr 29, 2010
See Charge roller my be dirty or Catriges PCU Units
Ricoh CL3000E... | Answered on Mar 31, 2010
It sounds like the drum units are filling up with waste toner. Check the ends of the drum unit and make sure the shutter that allows waste toner to exit the drum unit is opening.
Ricoh CL3000E... | Answered on Jul 01, 2009
open rhs panel, lift flap, remove waste toner container and then slide out black pcu.
Ricoh CL3000E... | Answered on Dec 04, 2008
the vertical line that you saw is an indication of either it is normally worn out, or something has caused the scratched, by any material ( PC drum is very sensitive to any material and can easily damaged or scratched any solid and unwanted dirt inside) see you actual meter reading. if it falls on the first thousand copies or print then it might have caused by a scratched, if it falls beyond the PM parts repalcement then there is nothing you can do but to replace this.
sometimes you can swap the colors, by the affected color use the yellow drum unit to the affected drum, the vertical would not that be obvious.
Ricoh CL3000E... | Answered on Jul 24, 2008
In my experience, the fuser has always been the cause of the lines.
Ricoh CL3000E... | Answered on Jul 10, 2008
Couple of things to try: - If you just emptied the waste cartridge then you have to take the bottle back out and clean the insides as well. The sensor sees the toner on the walls and still thinks it?s full. FYI as typical the manufacturer recommends replacing the bottle with a brand new one. - If not that then you may have toner covering the optical sensor. Try blowing the area where the waste bottle attaches to the printer with canned air. Let us know if you have any other questions and please don?t forget to rate this post.
Ricoh CL3000E... | Answered on Jul 07, 2008
Where best to look will depend a little on the nature of the smudge. If what you're looking at is white, then you might just have a little heap of toner or paper dust on part of the LED array that paints the picture onto the photoconductor drum (look for a narrow unit that stretches full width, adjacent to the drum. Dark marks may, if you're lucky, be down to dirt on charger wires. Both respond well to cleaning with a vacuum and a soft cloth (be very gentle if cleaning the wires). I would be inclined to trust the existing photoconductor unit unless you know it's been abused (e.g. by leaving it lying around in daylight) or the coating on the drum is visibly damaged. A.
Ricoh CL3000E... | Answered on Sep 16, 2007
Ricoh CL3000E Laser Printer Logo
Popular Tags
34 questions posted
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Ricoh Office Equipment & Supplies
Most Popular Question
reset ricoh cl 3000 transfer belt
  • Office Equipment & Supplies
