20 Most Recent
Sony HDR-CX130E FULL HD FLASH MEMORY PAL CAMCORDER Questions & Answers
I cannot charge the battery using the ac adapter or USB port on my computer even the charge lamp does not light up can you please help
If a lithium battery is too deeply discharged or the cells matching become unbalanced from many deep discharges, then it can be permanently damaged. The chargers often have over discharge detection circuits, which prevent you from recharging the battery under these circumstances. This is because the battery when overdischarged, could vent or overheat etc. if recharged.
Overdischarge can happen if you don't recharge the camera after using it and then leave it in the closet for a long time before trying to recharge.
This often happens with laptops if you don't remove the battery when storing it for months. The laptop uses a small amount of current even when switched off and this causes the over discharge.
Best bet is to try and charge a new battery, to see that the charger is ok.
Need usb transfer cable code or number for a sony cybershot n50
I believe you are looking for a USB transfer cable for your Sony Cybershot N50. I found a replacement USB camera transfer data sync charging cable cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300, DSCW370, DSCW800, DSCW830, DSC-H200, DSC-H300, DSC-W370, DSC-W800, DSC-W830 digital camera on Amazon . This cable is compatible with several Sony Cybershot models, including the N50. The cable is priced at $7.95 and comes with a 30-day return policy.
Amazon.com: Replacement USB Camera Transfer Data Sync Charging Cable Cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300,DSCW370,DSCW800,DSCW830,DSC-H200,DSC-H300,DSC-W370,DSC-W800,DSC-W830 Digital Camera (Black) : Electronics
1/23/2024 10:01:12 PM •
Sony Cameras
Answered
on Jan 23, 2024
How can I change the language on my Sony DCR PC-100? I'm trying to change it from Japanese to English but I cant seem to find the solution online as well as from reading the manual.
The Sony DCR-PC100 is a camcorder model that was released before touch screen interfaces and language settings became more common on consumer electronics. As such, it's possible that this specific model might not have a built-in option to change the language from Japanese to English, especially if it was originally sold for the Japanese market.
However, there are a few general steps you can try that might help:
- System Menu: Check the camcorder's settings menu for any language-related options. Look for a "System" or "Language" menu where you might be able to change the language settings. Keep in mind that the menu options might still be displayed in Japanese, so you might need to rely on symbols or context.
- Reset to Defaults: Some devices have a "Reset to Defaults" option that might reset all settings, including language, to the factory defaults. This might be worth trying if you're unable to find the language settings.
- Contact Sony Support: If you're unable to find a solution through the manual or online resources, it's best to contact Sony customer support for your region. They might be able to provide specific guidance or let you know if changing the language is even possible on the DCR-PC100.
- Third-Party Resources: Search for user forums or online communities where other users might have faced a similar issue and found a solution. Sometimes, enthusiasts or experts in those communities can provide helpful insights.
- Professional Assistance: If all else fails, consider reaching out to a professional technician or service center that specializes in Sony camcorders. They might have experience with older models and could potentially assist you.
8/5/2023 10:14:51 AM •
Sony Cameras
Answered
on Aug 05, 2023
SONY DSC-S40 RESET IT SELF.
If you have already cleaned the lens gears and the issue persists, it is possible that the lens electric motor is not working properly. You can try resetting the camera to see if it helps. Here are the steps to reset the Sony DSC-S40:
- Turn off the camera and remove the batteries.
- Wait for a few minutes before reinserting the batteries.
- Turn on the camera and see if it works.
If the camera still does not work, it may be a hardware issue and you may need to take it to a professional repair service or contact Sony support for further assistance.
2/26/2023 2:52:49 PM •
Sony Cameras
Answered
on Feb 26, 2023
