20 Most Recent
Samsung V20 XTC 1800 Notebook Questions & Answers
How to connect ribbon cable from the touchpad to motherboard?
Hi Rob.
The little black plastic clip either pulls up or forward depending on the connection.
If the tab pulls up, slot the ribbon cable in as far as it will go and push the tab down to lock the cable in place.
If the tab pulls forward, again pop the cable in and push it back to lock it into place.
Ge gentle with the cable and the tab as they can be broken easily.
Good luck
My NC10 netbook works normaly
first thing i to check psu model specs,(should be on sticker on psu) is as supplied with your model(manufacturers site)
Everytime i turn on the laptop PhoenixBIOS setup
Yes, 2 things
1st, are you pressing any keys to ask it to enter the setup? If yes, why?
2nd, if it is always going into setup when turned on, then there is a fault with the current NVRam setup. If it does NOT give you an option to continue, then you will most likely need to send it to the manufacturer for repair. OR a phone call or chat session to them and they may be able to give you solution.
I know if the hard disk is password protected, they will not give assistance over the phone as them make an assumption if you set the password you would remember it and if you did not then you most likely should not be accessing the hard disk.
Installing built in mic
On your task bar look for a speaker symbol
right-click
click on adjust sound properties or something similar
there you can configure the microphone
DVD Drive
once the screw is removed, you may need to insert the tip of the screwdriver, behind a small curved plate, where screw went in. Also, on outside of the laptop, there is usually a small button/tab key, which may be pressed in, then retracted, to pull the DVD drive out of it's bay.
Webcam
your creative live webcam probably have no problems it just have some complicated process when installing that cam...
your logitech webcam have no problem either if you can make it work with the cam your sound problem maybe just in your sound settings... if that logitech cam is what i think it is it has a built in microphone...
double click the speaker icon in your bottom right most taskbar (close to the time)
the volume control will popped out click on the microphone advance button then on advance control for mic windows uncheck the mic boost...
the mic probably getting a loop static from your speaker...
rate me if this help........
Maquina de lavar Samsung wf90f5e5u4w
ENGLISH ONLY please.
Samsung washing machine wf90f5e5u4w
Hello good afternoon, I want to ask for help, I have a faulty module and I wanted to ask if you have the electronic diagram for the Samsung DC92-01240C washing machine, the machine model wf90f5e5u4w, I would really appreciate it if you could, thank you. greetings Antonio Paulo
Steam Wash, Washers Support ' Samsung Care US
Samsung
https://www.samsung.com > washers > front-load > ste...
Get the latest drivers, manuals, firmware, and software. Learn more. Request repair service. Arrange for a service visit at home, schedule a walk- ...
https://www.google.com/search?q=Samsung+DC92-01240C+service+manual
12/4/2023 10:19:25 PM •
Samsung...
Answered
on Dec 04, 2023
