20 Most Recent Samsung ML 1510 Laser Printer Questions & Answers
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Samsung ML 1510... | Answered on May 11, 2017
Change the toner cartrigde or refill (is easy to refill the toner) and change the cartridge chip.
Samsung ML 1510... | Answered on Feb 20, 2013
I have a Mac Mini using Samsung ML-1510 and recently upgraded to Lion. Splix makes it all work: http://guigo.us/mac/splix/
Samsung ML 1510... | Answered on Aug 13, 2011
hi, could be an incorrect driver, i guess. if that's the case, getting a right one should work. if you tried samsung site but still no help there, hope this site for printer drivers can help you get a working one easily and correctly instead:
http://tinyurl.com/6x8ky6b
hope this helps you. good luck.
Samsung ML 1510... | Answered on Mar 04, 2011
use windows xp driver.
Samsung ML 1510... | Answered on Feb 23, 2011
Access the manufacturer's web-site: http://www.samsung.com
and choose "downloads" or "support".
Enter your specific model-number.
Select your Operating System.
Download.
Install.
Samsung ML 1510... | Answered on Nov 06, 2010
1st You download Printer Driver. Samsung Laser Printer Driver After this install the Printer driver in the system.
Installation of Printer Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Samsung ML 1510... | Answered on May 04, 2010
the fuse. Get the manual on line. Check www.samsung.com You will find the issue there and the steps to follow
Samsung ML 1510... | Answered on Apr 25, 2010
plz download the drivers from the manufacture site and install it
Samsung ML 1510... | Answered on Mar 07, 2010
This is due to toner may get over. Remove the toner catridge and shake the same and reinsert may solve your problem. Also change the toner catridge if required and check.
Revert back for more assistance.
Samsung ML 1510... | Answered on Jan 20, 2010
Try this driver (Its from there site, stating its for Windows 7 as well)
I hope this will help you out.
Regards, WAQAR.
Samsung ML 1510... | Answered on Nov 29, 2009
Samsung ML 1510 Laser Printer Logo
44 questions posted
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
ML Samsung
  • ML Samsung
Most Popular Question
recently purchased imac
  • Office Equipment & Supplies
