20 Most Recent Samsung (MP0804H) 80 GB Hard Drive Questions & Answers
I f ur hearing a whirling and clicking noise in ur HDD, that means it is already BUSTED and needs to replace! The internal LENS can't read the disk anymore! Taah!
Samsung... | Answered on May 01, 2013
click start control panel scroll to folder options this may vary depending on your operating system place a tick in the single click to open a folder option or if you right click on the drive/folder select properties there will be an array of options in the security tab make sure you have full control
click start control panel user accounts on the users tab,click the name of the computer administrator you must have full control be the computers "administrator"
hope this helps
Samsung... | Answered on Apr 17, 2011
To configure the hard drive as a slave drive, you need to set a jumper on the hard drive to SL (slave)
The other jumper settings are MA (master) and CS (cable select).
Samsung... | Answered on Mar 19, 2011
Try some of these solutions:
  1. http://support.microsoft.com/kb/297185
Your best bet is the chkdsk /f /r method.
Samsung... | Answered on Mar 01, 2011
What sort of drive is it? - IDE, EIDE, SATA, SCSI etc - what are you using to try to format it?
What operating System are you using?
Samsung... | Answered on Feb 15, 2011
You do NOT need to buy a new Samsung disk-drive.
You can buy a replacement from Western Digital, or from Seagate/Maxtor, or any other manufacturer.
Take your current Samsung disk-drive to the computer-store, so that they can sell you a new disk-drive with IDENTICAL data/power connectors (either Parallel-ATA or SATA).
Samsung... | Answered on Feb 01, 2011
maybe your HDD are not compatible in your laptop. try to look it in your manual if it is compatible or not.
Samsung... | Answered on Dec 17, 2010
you have not listed the problem so i guess
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Samsung... | Answered on Dec 11, 2010
coniccompute
If your hard drive is not showing up in My Computer you may need to confirm that the drive is showing in disk management. The links below will help you do this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
If the drive still will not show up make sure that the drive is getting power. You also may have a bad data cable.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Samsung... | Answered on Nov 18, 2010
Bad sector in your hard disk, format in win98 bootable cd
Samsung... | Answered on Oct 27, 2010
It's probably out-of-warranty. It's time to replace it.
Samsung... | Answered on Oct 26, 2010
go to the samsung support and check on RMA status of the drive by it's number
I’m happy to help further over the phone at https://www.6ya.com/expert/troy_d840d2702258460c
Samsung... | Answered on Oct 15, 2010
Samsung HDD comes with a 5 year hardware warranty...
Samsung... | Answered on Sep 29, 2010
good day,
try to reformat you hard disk,. if its a physical defect then there is no way you can fix it.
on the other hand, if you are familiar with RMA, then you could send the defective Hard disk that you have to the Manufacturer and they will replace it brand new...
Samsung... | Answered on Sep 24, 2010
Just visit the shop where you have purchased your pc or just try out the bill when u purchased they mention how many they provided warranty
Samsung... | Answered on Aug 20, 2010
Hello their sam4ubabe
So you mean you Took it off and put it back again...
Try this sequence:..
1. Remove your Hard disk
2. Clean it, remove Dust particles around the connectors
3. Put back the Hard disk, don't tight it so much.
4. Put back those Connectors from Hard disk connectors and Power Connectors.
5. Push the connectors to tighten contacts.
Power it ON.
Lets see if it goes back.
-dontput
Samsung... | Answered on Aug 17, 2010
Samsung (MP0804H) 80 GB Hard Drive Logo
51 questions posted
Top Samsung Computers & Internet Experts
asber
RONALD CARTER JR
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Computers & Internet
Most Popular Question
samsung 2 5
  • Computers & Internet
