20 Most Recent
HP Hewlett-Packard - LaserJet Pro M1217nfw MFP Questions & Answers
Initializing
NVRAM Initialization: 1. Turn the printer off. 2. Press and hold down CANCEL (X) and Start Copy (button just below the X button) buttons at the same time while powering on printer. *Keep these buttons press while you power on the printer* 3. Continue to hold down buttons until the printer display reads PERMANENT STORAGE INIT. 4. Release the buttons when "PERMANENT STORAGE INIT" is displayed. Printer will return to Ready automatically.
6/10/2023 7:05:30 PM •
HP...
Answered
on Jun 10, 2023
Scanner error 8
you printer ccd unit is damaged or short so replace ccd unit
5/6/2014 2:43:24 PM •
HP...
Answered
on May 06, 2014
Prints black page
please replace the cartridge or dc controle card or engine controle card
5/6/2014 2:39:42 PM •
HP...
Answered
on May 06, 2014
Ink Cartridge removal
stop sending any command to your printer, just open the cover of it and it will move to the middle in order to remove your cartridge, if nothing happens just pull it back with hand, it will move freely..
4/15/2014 7:44:35 AM •
HP...
Answered
on Apr 15, 2014
Ink cartridge jammed
Download Hp Doctor and it can show you what to do
4/15/2014 7:39:49 AM •
HP...
Answered
on Apr 15, 2014
I have m1217nfw is there convertor to power from 110v to 220v
I have worked on laserjets for years now and have never heard of a power convertor. The power supply will be a 110v device and if you want to use it in the uk you will need to replace it with a 220v one. I am unable to find a parts list for a laserjet M1217. However you must look for the C number which will be on a label. Note this and go to HP.com site and click on the parts link. Enter the c number and it should find what parts are available. If it does not find anything then HP will not supply parts but as its a laserjet there should be some available.
3/14/2014 9:34:51 PM •
HP...
Answered
on Mar 14, 2014
HP 1217 M1217 nfw MFP won't receive fax
Having the TAM set to four rings seems a bit high to me. Decrease the ring count on the Tam. the fax ring count does not really matter.
Keep your outgoing message to a minimum . if too long the calling machine will time out and drop off the line.
see how that goes. Also are you using the genuine adaptor lead. Does the tam actually ring? I suspect not. there are literally loads of adaptor leads that will fit and look the same but they are wired internally for that make only.
1/30/2014 6:34:35 PM •
HP...
Answered
on Jan 30, 2014
How to clear memory
the problem with my hp laser jet profession M1217nfw MFP ,receiving faxes
8/18/2013 6:05:01 AM •
HP...
Answered
on Aug 18, 2013
