20 Most Recent
Vision Fitness T9600 Treadmill Questions & Answers
The belt catches when running. it is fine when walking. Vision Fitness T9250
There is a special lubricant spray for treadmills that you spray. injection pump. The air injection pump is designed with a check valve inside which only allows air to flow in one direction, preventing exhaust gases from escaping through the air pump and only allowing air to enter. When this check valve fails, moisture is able to get inside the air pump. Make sure you don't have dirt and dust build-up before spraying.
