20 Most Recent
Xerox WorkCentre 7425 7428 7435 Second Bias Transfer Roll 008R13064 Questions & Answers
How Do I Reset Counters of Xerox Workcentre 7435 Toner Chips ?
You can't. It is hard wired in programmed memory. The reason is because most Xerox printed are supplied on a consumables deal where you have to buy toner direct at a slightly inflated price to cover the lowered lease cost of the machine. These machine also 'phone home' for interrogation..
Error code 116-323 in xerox 250
error code 116-323 on a Xerox WorkCentre 250 series printer typically indicates a problem with the Transfer Belt Unit. This unit is responsible for transferring the toner from the imaging drum onto the paper during the printing process. Here are some steps you can take to troubleshoot and potentially resolve the issue:
- Power Cycle: Turn off the printer and unplug it from the power source. Wait for a minute or two, then plug it back in and turn it on. Power cycling can sometimes clear temporary errors.
- Check Transfer Belt: Open the printer's front cover and locate the Transfer Belt Unit. Ensure that the Transfer Belt is installed correctly and that there are no visible signs of damage or obstruction.
- Clean the Transfer Belt: Dust and toner particles can accumulate on the Transfer Belt, affecting its performance. Gently clean the Transfer Belt with a soft, lint-free cloth or a cleaning pad designed for this purpose.
- Reset Printer: Some printers have a reset option or a combination of buttons to clear error codes. Refer to the printer's user manual or Xerox's support documentation for instructions on how to reset the printer.
- Update Firmware (if applicable): Check if there are any firmware updates available for your Xerox WorkCentre 250 printer. Updating the firmware might address known issues and improve printer performance.
- Check Consumables: Verify that all consumables, including toner cartridges and imaging drums, are correctly installed and not depleted. Replace any depleted consumables with new, genuine Xerox supplies.
- Check for Paper Jams: Ensure there are no paper jams or obstructions in the paper path that might be causing the error
Fuji Xerox ApeosPort-IV C4430. It has 116-331 fault code error. Any assistance to remove and get it done??
Question edited for clarity.
Power Cycle it.
Fault Code 116-331
Xerox
https://www.support.xerox.com > en-us > article
Jan 19, 2021 - Power off/on the printer. For details, refer Power Off the Printer Using the Power Switch. Wait Two Minutes and Then Power On the Printer.
Missing: C4430 ' Show results with:
C4430
Thread: Error 116-331
Copytechnet
https://www.copytechnet.com > ... > Xerox
Jan 20, 2012 - Hi, 1. Check and reset all connectors on ESS PWB and HDD. 2. Press and hold the 4, the Stop, and the Power Save buttons on the Control Panel ...
Xerox workcenter 5225 show error code 116-331
Sep 10, 2019
Dead Machine 242 code 116-331
Sep 10, 2019
WC 6515 Error 116-331
Jun 6, 2019
xerox workcentre 5225 116.331 error code
Sep 6, 2012
More results from www.copytechnet.com
C4430
Need urgent help with Error Code 116-331! It's a PrimeLink ...
Reddit
https://www.reddit.com > Xerox > comments > need_u...
Nov 26, 2022 - 116-331 is usually just a corrupted job. Power off the machine using the button behind the front door. (not the button on top). Press and hold # ...
