20 Most Recent
Kyocera Km-f1060 Printer/fax Machine Questions & Answers
What is code Kyocera 3212i error code C3800
The error code C3800 on a Kyocera 3212i printer indicates an AFE error. This error occurs when writing data and reading data does not match 3 times continuously, or there is no response from AFE for 100ms. The following steps can be taken to resolve this issue:
Check the connection FFC is not connected properly. Or it is faulty. Clean the FFC terminals of the following FFC and reconnect them.
If the issue persists, consider contacting a Kyocera technician or service provider for further assistance.
Kyocera Printer wont scan
Check Network Connection: Ensure both devices are on the same network.
Restart Devices: Power cycle both computer and printer.
Verify Scanner Settings: Confirm correct scanner selection.
Update Drivers: Install latest printer drivers.
Firmware Update: Consider updating printer firmware.
Inspect Cables: Check all connections.
Contact Kyocera Support: If issue persists, reach out to Kyocera's support.
Kyocera km 3050 has a new toner but says toner empty
If your Kyocera KM 3050 printer is displaying "toner empty" message, even though you have replaced the toner cartridge with a new one, it's possible that the toner sensor inside the printer is malfunctioning or is dirty. You can try the following steps to fix the problem:
1. Open the front cover of the printer and remove the toner cartridge.
2. Look inside the printer, and you should see a small sensor that detects the toner level. This sensor may be dirty or covered with toner particles.
3. Clean the sensor with a soft, dry cloth and reinsert the toner cartridge into the printer.
4. Close the front cover and power on the printer.
If the problem persists, try resetting the printer's toner counter. Here is how to do it:
1. Press the "System Menu" button on your printer.
2. Scroll down to "Service" and press the "Enter" button.
3. Scroll down to "Maintenance" and press the "Enter" button.
4. Scroll down to "Reset Toner Counter" and select it.
5. Restart the printer and check if the problem has been resolved.
If none of these steps work, there might be a more serious hardware issue with your printer's toner sensor, and it's advisable to contact a Kyocera printer support expert or service center for assistance.
