20 Most Recent Soyo P4I875P Dragon 2 Motherboard Questions & Answers
The internal battery on the motherboard used for CMOS backup.
It is 3V Lithium Battery. Many companies manufaturing this battery. You can purchase it of any company.
Soyo P4I875P... | Answered on Sep 22, 2009
Either the cord isn't hooked up, a pin is bent, or the computer isn't sending a signal. In the last case, you may need a new graphics card.
Soyo Computers &... | Answered on May 11, 2018
Go to Device Manager - locate your monitor - delete it with drivers - reboot the system
Soyo Computers &... | Answered on Mar 28, 2017
this can be your computer issue not monitor try connect to other monitor and make sure your computer is working fine ,you can check all the lights on the computer are on and getting no beeps sounds usually you will hear a single beep when PC is booting well
Soyo Computers &... | Answered on Jul 28, 2016
you install a application in your pc
application name is " realtek audio driver
Soyo Computers &... | Answered on Mar 24, 2016
Out of range indicates that you have attempted to use a resolution the the monitor is incapable of handling.
Lower your resolution and try again until you can get it to do what you wish then try to do each monitors resolution individually.
Soyo Computers &... | Answered on Nov 01, 2014
The usual method is to press the menu button and follow the on screen prompts, have you done that?
Soyo Computers &... | Answered on Jul 18, 2014
If you mean the light on your monitor is orange instead of green, it means the monitor is not receiving data from the computer.
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Soyo Computers &... | Answered on Jul 16, 2014
youight cheak the leads first
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Soyo Computers &... | Answered on Jun 22, 2014
go in to cmos bio string will be there http://www.computerusermanual.com/user-manuals/SOYO-SYP4VTE-User-Manual.html
Soyo Computers &... | Answered on May 27, 2014
http://download.cnet.com/Net-Viewer/3000-2356_4-10034828.html
Soyo Computers &... | Answered on May 22, 2014
http://www.elhvb.com/supportbios.info/Archives/MANUAL/SOYO/mp4vx2l10.pdf
Soyo Computers &... | Answered on May 18, 2014
Soyo P4I875P Dragon 2 Motherboard Logo
2 questions posted
Top Soyo Computers & Internet Experts
Ekse
Marvin
Marvin
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Soyo Computers & Internet
Most Popular Question
kind internal battery
  • Computers & Internet
