20 Most Recent
Sony Cyber-shot Dsc-w610 14.1MP Camera Digital Questions & Answers
Error formatting memory card
For compatibility of the Sony memory stick (Duo), check the manual. Sony is the only brand that is making memory cards, witch are not all compatible with their own cameras. Then check if the card is not locked, not damaged, and if all contacts are clean and shiny. Also check in the camera if nothing (dust or debris) is in the memory card holder. Make sure you did not put protected files on the card, although the camera should not look for the last one, when you try to format a memory card in there.
No memory card message
try another memory card and if that doesn't work you should probably go to a local camera store or the place you bought your camera
CAMERA DISPLAYING MEMORY LOCKED
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Cannot get laptop to recognise sony digital camera dsc-w610
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Sony Cyber-shot Dsc-w610 14.1MP Camera Digital how to download video shots to PC
The best way to download videos (and photos) from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy videos and photos from the card to the computer's hard drive, the same way you copy any other files.
Digital camera bought in japan
Press the MENU button. Select the toolbox icon. Select the wrench-and-hammer icon. Select the second item on the menu. Select the desired language.
How do I remove the internal memory card
You don't need to remove the internal memory. Simply insert the memory stick, and the camera will store new images and videos to the stick instead of the internal memory.
How to get the date and time displayed on picture when printeddsc-W610
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.If you just want to view this data, just about any photo viewing/editing program should be able to display it. Again, please consult the documentation for whatever program(s) you're using.
Need usb transfer cable code or number for a sony cybershot n50
I believe you are looking for a USB transfer cable for your Sony Cybershot N50. I found a replacement USB camera transfer data sync charging cable cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300, DSCW370, DSCW800, DSCW830, DSC-H200, DSC-H300, DSC-W370, DSC-W800, DSC-W830 digital camera on Amazon . This cable is compatible with several Sony Cybershot models, including the N50. The cable is priced at $7.95 and comes with a 30-day return policy.
Amazon.com: Replacement USB Camera Transfer Data Sync Charging Cable Cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300,DSCW370,DSCW800,DSCW830,DSC-H200,DSC-H300,DSC-W370,DSC-W800,DSC-W830 Digital Camera (Black) : Electronics
1/23/2024 10:01:12 PM •
Sony Cameras
Answered
on Jan 23, 2024
