20 Most Recent Ironman Exerpeutic TF1000 Walk to Fitness Electric Treadmill Questions & Answers
0answers
My Exerpeutic TF1000 treadmill shows a E2 error, motor will not start.
see this steps and fix it.God bless youThis is probably a 1( faulty speed sensor, adjust it , clean it and tigh the plug very well see the diagram attached. 2( test the input voltage motor, if there are the motor need repair 3( test the output voltage board, for input voltage motor, if there are NOT the board is faulty see the block diagram . The error codes will differ between makes and models but could be e1. or e2Run the software calibration for easy diagnostic, troubleshooting, and fix it. God bless you10_2_2012_10_07_50_am.gif10_2_2012_10_08_13_am.gif10_2_2012_10_08_36_am.gif
10/2/2012 10:08:45 AM • Ironman... • Answered on Oct 02, 2012
2answers
My heart rate monitor does not work when gripping the hand bars.
please follow the steps and fix it. God bless you
1) Make sure the heart rate monitor is under your clothing, against your skin, and as high under the pectoral muscles as is comfortable. Note: If the heart rate monitor does not function when positioned as described, try moving it slightly lower or higher on your chest.
2) Make sure the logo on the sensor is facing forward and is right side up.
3) Use saline solution (saliva or contact lens solution) to wet the two electrode areas on the sensor unit. If the heart rate readings do not appear until you begin perspiring, re-wet the electrode areas.
4) As you walk or run on the treadmill, position yourself near the center of the walking belt. For the console to display heart rate readings
5) The heart rate monitor is designed to work with people who have normal heart rhythms. Heart rate detection problems may be caused by medical conditions such as premature ventricular contractions (pvcs), tachycardia bursts, and arrhythmia.
6) The operation of the heart rate monitor can be affected by magnetic interference caused by high power lines or other sources. If you suspect that magnetic interference may be causing a problem, try relocating the treadmill.
7) If the heart rate monitor still does not function properly, test it by having another person try it.
6/28/2017 1:44:40 PM • Ironman Exercise... • Answered on Jun 28, 2017
Error code E6 on Trojan Stamina 320 how to fix
How to fix error code e6
4/21/2016 4:33:30 PM • Ironman Exercise... • Answered on Apr 21, 2016
Can I order a new key mine is lost
Contact Heys fitness http://www.keysfitness.com/ http://www.keysfitness.com/index.php?menu=contact and ask them if they can help you
10/29/2015 9:30:18 PM • Ironman Exercise... • Answered on Oct 29, 2015
Ironman Exerpeutic TF1000 Walk to Fitness Electric Treadmill Logo
7 questions posted
Top Ironman Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Ironman Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Ironman Exercise & Fitness
Most Popular Question
exerpeutic tf1000 treadmill shows e2
  • Exercise & Fitness
