20 Most Recent
Dell Vostro 460 Mini Tower Desktop Sandy Bridge I52500 33ghz 4gb Ddr3 Memory 320gb Hdd Win 7 H (678822608225 Questions & Answers
Bluetooth & sound
Generally, connecting phones via bluetooth to a laptop just allows for file transfer between the two devices. It is not to input sound from the phone through the speakers of the laptop. You would need a bluetooth audio device for that such as bluetooth speakers or headphones
Code 10 is not starting
This error is basically saying that Windows, for one reason or another, cannot communicate properly with one of your programs. This communication problem is usually caused by out-of-date, missing or corrupt device drivers. ... Select Start > All Programs > Windows Update.
This copy of windows is not genuine
i used to get that also, I wrote down windows numbers from windows sticker on the side of machine, (needed magnifying glass) and went online to windows verify, after they scan it, it came out good
HOWCAN FIND MACADRESS WIFI LAPTOP VOSTRO1500?
Open a command prompt ( Windows key + R to open Run box, then cmd), and type
ipconfig /all
and look for the wifi adapter. The entry labelled "Physical Address" is the MAC address. It will look something like 84-3A-4B-C8-E9-B7
(Your router might want it entered in the format 84:3A:4B:C8:E9:B7)
Cpu overheating
The cooling fins on the processor chip are plugged with dust. The fan may not be turning fast enough. If that's the case you'll need to replace the cooling fan
Wifi hotspot
WiFi will in the laptop will connect to a wireless router or a hot spot. The laptop itself has no hot spot built in.
Windows update failure (KB982670)
Believed me you have to reinstall your operating system. I encountered that problem too. I uninstall and re-installed .NET, update windows service packs nothing happened until I reformat the hard drive and install the operating system again.remember format the hard drive first then install the operating system (backup your data first)
How to lock the Window 8 dell laptop
Hi Anonymous,
Try pressing the Ctrl+Alt+Delete keys together and now press lock the computer. However, if this doesn't help do let me know.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
