20 Most Recent
Dahle 41214 Shredder Questions & Answers
Dahle 40434 not shredding.
How is the lubricating oil tank for fill level? Automatic OilerQuoteJust like any fine-tuned machine, your shredder needs to be properly oiled to run at peak performance. This shredder is equipped with an EvenFlow Lubricator which provides slow, continuous oil across the entire cutting mechanism.Also check for anything jamming the blades and forcing them apart. There may be an adjustment for tension. I have never seen a shredder with cutting rollers like this before!
https://www.dahle.com/shredder/item/40434It is a $5,000 machine, so you might reach out to Dahle if oiling isn't the problem...
Paper full warning on constantly
The most common reason for a false reading, where the bin full light comes on but the shredder basket is empty, is simply dirty sensors on the bottom side of the shredder head.
Dahle 21082
Most shredders have strict rules about running times. Usually the motor cuts off after 5 minutes use (or thereabouts) and you have to wait for a sensor to cool down, maybe 15 minutes
20822 Department shredder
The motor has a feature to go forward and reverse and thus the forward (paper in) control has been compromised. The problem can be the switches. A rocker switch when in one position may control the forward motion or backward motion, therefore if the switch fails only one side is working. Then there may be two small switches on the so called rollers (Cutters) that sense the input of paper into the cutters thereby starting the motion and shredding procedure. If a sensing device is broken, only the unaffected switch works. Repair is usually expensive, thus a replacement is in order.
