20 Most Recent LG LMHM2017ST Microwave Oven Questions & Answers
Lg lmhm2017st stopped working.
a problem with the control card that controls the functioning of the microwave
6/7/2014 11:46:47 PM • LG LMHM2017ST... • Answered on Jun 07, 2014
My new LG solardome MA3884vc overheats melamine plate @30 seconds
If your LG Solardome microwave oven is overheating a melamine plate within 30 seconds, there could be a few potential issues at play:
  1. Power Settings: Check to see if the power settings on your microwave are too high. If it's set to a high power level, it can cause certain materials, like melamine, to overheat quickly. Try reducing the power level and see if that helps.
  2. Plate Material: Melamine plates are not suitable for use in microwave ovens as they can overheat and potentially release harmful chemicals into your food. It's recommended to use microwave-safe dishes made of glass, ceramic, or microwave-safe plastic.
  3. Microwave Performance: If the microwave is consistently overheating items within such a short time frame, it might indicate a malfunction. In this case, it's best to contact LG customer support or a certified technician to inspect and repair the microwave.
  4. Placement and Usage: Ensure that the plate is placed centrally on the turntable and not touching the sides of the microwave. Also, avoid using the microwave for extended periods without interruption, as this can cause overheating.
  5. Testing with Different Materials: Try using a microwave-safe ceramic or glass plate to see if the issue persists. If other materials heat up quickly as well, it could indicate a problem with the microwave itself.
3/8/2024 3:08:42 PM • LG Microwave... • Answered on Mar 08, 2024
I have an lg convection microwave oven. Can I use foil while using convection roasting?
I have a new Kitchen Aid Convection Microwave with air fryer. I've not yet used the air fryer, but today I put a pan with a roast and set to convection roast and turned it on. I put the aluminum foil over the top of the pan and it sparked. I don't know why this happened. I'd sure like someone to let me know.
1/28/2024 12:31:51 AM • LG Microwave... • Answered on Jan 28, 2024
My LG microwave says PM in the morning. How do I change it to AM. THE MANUAL DOES NOT address this. Model LMV1683ST
Push clock button and press the Up/down buttons to change time to pm.
11/5/2023 2:52:13 PM • LG Microwave... • Answered on Nov 05, 2023
On the roof of my lg solardom microwave there is a hole in brown plate and arching. Can it be fixed?
Remove the contaminated and fit a new Waveguide cover.
3/23/2023 8:08:01 AM • LG Microwave... • Answered on Mar 23, 2023
How to remove door COVER from door of LG Microwave model LMHM2017ST
Here are the steps to remove the door cover from the door of your LG Microwave model LMHM2017ST:
  1. Unplug the microwave from the power source.
  2. Open the microwave door and locate the four screws on the inner edge of the door.
  3. Use a Phillips screwdriver to remove the four screws.
  4. Carefully separate the outer door panel from the inner door panel.
  5. You will now see the door cover attached to the outer door panel.
  6. Use a flathead screwdriver or plastic pry tool to gently pry the door cover off of the outer door panel. Start at one corner and work your way around the edge.
  7. Once the door cover is removed, you can replace it with the brushed silver cover from the new door.
  8. To reassemble the door, simply snap the new cover onto the outer door panel and then reattach the outer door panel to the inner door panel using the four screws you removed earlier.
Make sure to be careful when removing the door cover, as it can be fragile and may break if handled roughly.
2/26/2023 5:09:19 PM • LG Microwave... • Answered on Feb 26, 2023
LG LMV1773SS microwave. Where are the fuses located on it please?
Question edited for clarity. It depends where you live? In the UK, the fuse is in the wall plug. In the US and other countries it _may_ be at the rear where the mains lead goes in. Sometimes they pull out, sometimes there is a small screw cap. If you are thinking of getting inside it, this Tip I wrote applies. https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
11/19/2022 1:37:48 AM • LG Microwave... • Answered on Nov 19, 2022
LG microwave door open pad broke.
Question edited for clarity. Question moved from Building Materials to LG Microwave. Take into an LG Service centre for repair. They are sealed by security screws and are dangerous inside. You won't be able to get parts.. If it is a counter top microwave and cost $60, just buy a new one as they are a disposable item.
4/5/2022 2:54:00 PM • LG Microwave... • Answered on Apr 05, 2022
Our LG microwave is only 1.5 years old and cooks fine but has recently started to emit what smells like an electrical burning smell.
if smells like something then something is burning stop using answer about can it be fixed is unknown till diagnosed
1/5/2022 4:48:48 PM • LG Microwave... • Answered on Jan 05, 2022
LG microwave will not work unless you slam door repeatedly
latch/catch failure
11/6/2021 6:55:47 PM • LG Microwave... • Answered on Nov 06, 2021
2answers
I have a mg6644BS LG Microwave and need the spec's for the FUSE (says Special Fuse) please?
THE HIGH VOLTAGE FUSE IS IN A PLASTIC EXTRUSION NEXT TO THE CAPACITOR AND DIODE. YOU CAN USE 3 OR 4 STRANDS OF THIN WIRE FROM MULTI STRAND 15A MAINS CABLE. SOLDER IT OVER THE BLOWN FUSE. I HAVE DONE THIS 100'S OF TIMES.
7/24/2021 2:01:23 AM • LG Microwave... • Answered on Jul 24, 2021
My Lg Solardom Oven Microwave is coming on but is not heating food what could the problem be.
Possible fuse for the magnetron power, capacitors or magnetron or all.
3/27/2021 12:23:35 PM • LG Microwave... • Answered on Mar 27, 2021
LG Microwave Clicking and Flashing
Go for a warranty repair anyway. It may be the magnetron, and the clicking is the big condenser discharging. https://www.lg.com/ca_en/support/warranty Microwave Ovens (Over-the-Range):
  • 1 year parts & labour
  • 5 years on the magnetron (part only)
Microwave Ovens (countertop):
  • 1 year replacement warranty
2/21/2021 8:11:43 PM • LG Microwave... • Answered on Feb 21, 2021
LG LMHM2017ST Microwave Oven Logo
8 questions posted
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
LG Microwave Ovens
  • LG Microwave Ovens
Most Popular Question
lg lmhm2017st stopped working
  • Microwave Ovens
