20 Most Recent Coldtech 40 cu. ft. / 1133 liter Commercial Freezer J2GF-40S Questions & Answers
Sounds like a loose wire since the move. Check you have power at the switch (in and out). If you have, check the starters and ballasts
Coldtech 40 cu.... | Answered on Apr 20, 2012
No. The compressor requires 230 volts.
Coldtech 40 cu.... | Answered on Aug 16, 2011
A defective temperature control can cause that problem.
Check by dialing it, it should be smooth when dialed.
It should be on desired degrees where you set it and not on other.
Thanks for asking.
Coldtech 40 cu.... | Answered on Jul 01, 2011
probably a short in the element or in the compressor
Coldtech... | Answered on Jul 11, 2019
you find that freezer shop it best if you fixed from shop where you freeze bought.
Coldtech... | Answered on Mar 26, 2013
The model number which you gave is not proper.But the nearest model number is J3GF-61S.In your model number its J36F but actual model number is J3GF. You will have to order the part from coldtech service center :--- Contacting ColdtechPhone: (800) 314-4477
Mail:
Jimex Corporation
1575 Zephyr Avenue
Hayward, CA 94544
USA.--------------
The online link providing this parts is as follows.Click the link:-- http://www.tmeinc.biz/xcold.htm ---------------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Coldtech... | Answered on Sep 09, 2010
http://www.ascendmfg.com/index.html
Go to this website. It is for Coldtech refrigeration. I could not find your numbers but you can contact them for information thru this site. Good Luck and hope this helps.
Coldtech... | Answered on Aug 16, 2009
do you have the old fuse? If so, carefully read the engraved markings on it
Freezers | Answered on Aug 25, 2019
a general E2 error involves the temp sensor or control board.It may be different for ruey shing. Try unplugging the unit for a minute and plug back in.
how do you know the power is on if all the lights are off?
If you are referring to the main supply, then maybe there is a reset button on the unit. If the unit is running, then without a manual I can't tell what the lights are for either.
Coldtech 40 cu. ft. / 1133 liter Commercial Freezer J2GF-40S Logo
8 questions posted
Top Coldtech Freezers Experts
Dennis Boxerman
Marvin
Marvin
ray gallant
ray gallant
Are you a Coldtech Freezer Expert? Answer questions, earn points and help others
View Most Popular
Coldtech Freezers
  • Coldtech Freezers
Most Popular Question
j2gf 40s coldtech display freezer
  • Freezers
