20 Most Recent Zodiac Sea Dragon GMT Black Dial Black Rubber ZO3701 Watch for Men Questions & Answers
The problem could be that the watch is defective.
Zodiac Watches | Answered on Feb 23, 2018
need more to help you put a photo on so i can help you
Zodiac Watches | Answered on Nov 23, 2016
  • Remove back
  • Locate battery. Note mounting arrangement for later battery replacement
  • Obtain replacement battery
  • Install battery
  • Check operation
  • Install back
  • Set time, etc.
Zodiac Watches | Answered on Oct 20, 2016
look at the stem , there might be a small plastic stop there that need removed then push in slightly on the stem
Zodiac Watches | Answered on Oct 30, 2015
If the watch parts are out of production (Generally speaking manufacturers only keep enough parts to make repairs for about 5 years) a revision is another way of saying the workings of the watch will be replaced but not with the same parts it came with. This is usually a modification to accommodate a new movement.
Zodiac Watches | Answered on Sep 17, 2009
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Watches | Answered 24 hours ago
Zodiac Sea Dragon GMT Black Dial Black Rubber ZO3701 Watch for Men Logo
1 questions posted
Top Zodiac Watches Experts
Ansel Alberto
Ansel Alberto
ray gallant
Are you a Zodiac Watch Expert? Answer questions, earn points and help others
View Most Popular
Zodiac Watches
  • Zodiac Watches
Most Popular Question
any idea get replacement rubber watch
  • Watches
