Keep the drill motor in the toolbox, you'll likely just ruin the safe.
Go here instead: https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination
There are 3 possible ways to unlock and access
the safe:
1. Factory code
(Found on the first page of the factory guide) You can
always open the safe by entering the pre-set 5-digit
factory code. This code cannot be deleted.
2. User code
If you prefer to employ your own code, you can
program the safe to open using a 5-digit user code
of your choice.
3. User pin
If you wish to give someone else temporary access
to the safe, you can program a 5-digit user pin that
can later be erased.
Programming the user code
NOTE: One (1) user code is allowed.
To add:
1. Press the Prog key , then enter the 5-digit
factory code.
2. Enter the 5-digit user code of your choice.
To delete:
1. Press the Prog key.
2. Enter the 5-digit factory code twice.
Programming user pin
NOTE: One (1) user pin is allowed.
To add:
1. Press the Prog key 2 times.
2. Enter your 5-digit user code.
3. Enter the 5-digit user pin of your choice.
To delete:
3. Enter 0, 0, 0, 0, 0.
NOTE: If your safe does not appear to be working,
please check batteries before calling Sentry
Customer Care.
wikiHow
https://www.wikihow.com > ... > Lock Picking
Grasp the handle and wiggle the magnet until the safe opens. Hold the magnet at the top left corner with one hand and the safe's handle with the other. Slide ...
Volume (in³): 2160 cubic inches
If you want to measure the cubic inches of a container, measure the length, width, and depth in inches. Then multiply those numbers by each other. For example, if your container is 5 inches long, 3.5 inches wide, and 7 inches deep, your calculation will look this: 5 x 3.5 x 7 = 122.5 cubic inches.
May 17, 2023
Cubic Inch Calculator
https://www.homedit.com/calculators/cubic-inch-calculator/#:~:text=If%20you%20want%20to%20measure,x%207%20%3D%20122.5%20cubic%20inches
Sentry Valueguard 1330 Safe Perfect for a home closet, office, etc... Outside dimensions: 22"x17"x17" Inside Dimensions: 14-3/4" deep 12" wide 15-1/4" tall Pic with water bottle is for size reference...
What you have is one of there products. You need to go to the following web address they have an on line form you fill out and will provide u with an opening combination.
https://www.sentrysafe.com/support/
You just buy another one, they are 50 bucks new.
Or contact Sentry Safe and see if they will sell you one.
Or take it to a locksmith and they will order and fit one for 75 bucks.
You are pretty stuck with that scenario. With an electronic lock you can use a rare earth magnet to pull the locking bolt but with a manual dial safe, you can't do that. I can remember my business safe combination from 1987 to 2005. You can also write it down.
Use a concrete saw or angle grinder and cut the back off it.
Question edited for clarity.
Although this guy makes it look hard work, they will usually bounce open quicker that this. You can also bang the top with a rubber mallet, or use a rare earth puck magnet to pull the actuator bolt.
If your Sentry Supreme 5330 safe is not opening, there could be a few possible reasons why:
Combination Error: If you are using a combination to open the safe, make sure that you are entering the correct combination. If you have forgotten the combination, you will need to contact Sentry Safe customer service to get assistance on how to recover or reset your combination.
Dead Batteries: If you have an electronic lock on your safe, the batteries may be dead. Replace the batteries and try again.
Jammed Bolts: The locking bolts may be jammed due to incorrect operation or a mechanical problem. Try tapping the safe door gently with a rubber mallet to loosen the bolts and then try to open it.
Mechanical Malfunction: If the safe still does not open, there may be a mechanical malfunction. In this case, you will need to contact a professional safe technician to diagnose and repair the problem.
Note: If you have lost your key, you will need to contact Sentry Safe customer service to order a replacement key.
The sound does two things
It lets you know you have done a positive button push.
It beeps when the battery is low to alert you to change them and save you having to cut the back off the safe.
It isn't programmable, snip the wire to the sounder, but it is likely hard soldered to the main board.
There are several possible reasons why your Sentry Safe MS3817 is not responding to the handle or new batteries. Here are some steps you can try to fix the problem:
Check the batteries: Make sure the batteries are properly installed and not depleted. You may also want to try using a different set of batteries to see if the issue is with the batteries themselves.
Check the battery contacts: Make sure the battery contacts are clean and free of any debris. You can clean the contacts with a soft cloth or toothbrush.
Check the handle: Make sure the handle is not damaged or stuck. You may need to apply some lubricant to the handle to loosen it.
Check the lock mechanism: Make sure the lock mechanism is not damaged or stuck. You may need to apply some lubricant to the lock mechanism to loosen it.
If none of these steps help, you may need to have the safe serviced by a professional. As for the factory code, it is recommended to contact Sentry Safe or the retailer where you purchased the safe for assistance. They may be able to provide you with the factory code or help you reset the safe.
To change the code on a Sentry Safe CSW3607, follow these steps:
Open the safe by entering the current code on the keypad.
Press and hold the "*" button on the keypad for three seconds. This will put the safe in programming mode.
Enter the current code on the keypad, followed by the new code you want to use.
Press the "#" button to save the new code.
Close the safe and test the new code to make sure it works.
It's important to note that the CSW3607 has a factory default code of "0000". If you have not changed the code from this default, you can simply enter the new code you want to use without going through the programming mode.
