20 Most Recent Jmlab Cobalt SW27A Speaker Questions & Answers
Check your connections. Make sure everything is plugged in properly. If it is still making a sound, even a whisper, then the amp is probably fine. Do you have other speakers connected to the amp? If so, they should be sounding too. If not, then it's definitely an amp problem. Ebay sells tons of .... well, everything, so you should check that out...
Jmlab Audio... | Answered on Mar 05, 2014
Hello unfortunately it sounds as if the coils in both woofers are open,you have pretty much confirmed this by your direct connection however putting an ohmmeter across the terminals will tell you as well.If you have a meter the woofer should measure approx 6 ohms,if it measures 0 its bad.Another simple way to tell is with a 9 volt battery,simply connect with two wires and see if the woofer pops if not its no good.
Jmlab Audio... | Answered on Feb 25, 2011
Try the Samsung website.
Audio Players &... | Answered 4 hours ago
If the Aiwa remote control you ordered is the applicable model for your Aiwa stereo, it should "pair" automatically.
Audio Players &... | Answered 7 hours ago
Request the template from the manufacturer/distributor.
Audio Players &... | Answered 8 hours ago
Absolutely, most Apple products are so simple it’s unbelievable how easy it is until you’ve actually done it! I’ve changed countless screens, battery’s, charging ports, and more with no experience, it simple and you can too. Get the parts from a reputablenevay seller as that’s most economical! See the attached link and the pictures, it’s too easy!
If you’ve found this helpful, please click the green “helpful” icon. If you have seconds leave a few words as a review or recommendation! Also, follow me for more answers to everyday issues, I’m all for saving you money and making the most of your time! Thanks and have a great day!
Audio Players &... | Answered Yesterday
System power is controlled by a switch on the right satellite speaker ON/OFF VOLUME control, therefore you would have to connect a separate switch to control power. However, you may be able to get a satisfactory result by turning the satellite volume control completely counter clockwise and adjusting the WOOFER VOLUME control to the desired level.
Hail to the Redskins
HTTR
Acronym Definition HTTR High Temperature Engineering Test Reactor HTTR Hail to the Redskins HTTR High Temperature Test Reactor (atomic energy) HTTR Highway to the Reich (gaming)
as we do not know what equipment you have , how are we to guess
it is rather unlikely they are .
I am having the same problem....
Audio Players &... | Answered 2 days ago
Jmlab Cobalt SW27A Speaker Logo
Popular Tags
0 questions posted
Top Jmlab Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Jmlab Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Jmlab Audio Players & Recorders
Most Popular Question
subwoofer repair
  • Audio Players & Recorders
