FixYa.com
Efficient Networks 5930 ADSL Business Gateway  Router
All Products > Efficient Networks > Routers
Problems with Efficient Networks 5930 ADSL Business Gateway Router?
Troubleshooting and Support
Solved Problems for Efficient Networks 5930 ADSL Business Gateway  Router RSS Feed Post a New Problem
Are NAT routers good firewalls ?
1 Solution
What ports do I need to open to permit VPN...
What ports do I need to open to permit VPN traffic?
1 Solution
configure DMZ Host
How do I configure the DMZ Host on my Router?
Post a Solution
where should I place my router?
I'm trying to get the best range possible, where should I place my router?
1 Solution
Does the ground fault interrupter (the...
Does the ground fault interrupter (the third prong on a three-prong socket) interfere with Powerline performance?
1 Solution
linksys wrt54gs cant connect..
Hello, I have this problem: I cant connect to my linksys wrt54gs, i cant ping to default ip 192.168.1.1,or connect...
2 Solutions
Quick repetitive disconnects
I've my router setup properly, but I encounter quick repetitiv e disconnects from time to time.Usually at disconnect,...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Efficient Networks 5930 ADSL Business Gateway  Router RSS Feed Post a New Problem
Firewall Updates (Software vs Hardware)
Does the concept of keeping a firewall patched with the latest updates apply to a software firewall, hardware firewall,...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Memory
Installed RAM8 MB
Installed Flash Memory4 MB
Dimensions
Depth5.99 in.
Height2.25 in.
Width11.74 in.
Weight1.54 lb.
Efficient Networks Contact Information
Main support number1-972-852-2000
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
