20 Most Recent Passport SR1 Radar Detector Questions & Answers
Looking for machanical means of starting a lister
lister what is a lister. im 65. this is posted to CAR RADAR DETECTORs. is this true?first state what it is.and model number or name.and age of device. if known.more input, can results i great answers.and be sure you are on the right forum here, Cars. ? or ?
11/10/2013 1:36:47 PM • Passport SR1... • Answered on Nov 10, 2013
2answers
I,m a south african,my visit visa for sudan was
I'd carry both the old and the new passport with you so they can actually see the visa number on the old one and see that the new passport has a new number. Anyone with common sense will be able to put 2 and 2 together but there are those that just like to give travelers a hard time.
11/4/2013 2:02:44 AM • Passport SR1... • Answered on Nov 04, 2013
0answers
Escort solo 2 won't power on
cinnatti microwave corp will repair the unit if returned to them,seems as if the power cable got switched around and power was reversed to unit causing internal fuse to blow. the chg is appox $25 takes about two weeks
11/14/2011 12:14:17 AM • Escort Vehicle... • Answered on Nov 14, 2011
I have an Rscourt Passport 9500 radar dtector that
  • Great conversation. The repair website is located here http://www.escortradar.com/service-procedure.php . I also suggested this might be a battery issue. Bird dogs and GPS's that remained plugged in non stop is very ******* the battery and a really bad battery will prevent startup regardless of being plugged in to a power feed or not.
  • Good luck to you.
Regards, Tony
9/4/2011 4:50:01 PM • Escort Vehicle... • Answered on Sep 04, 2011
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
3/28/2024 3:46:39 AM • Vehicle Parts &... • Answered on Mar 28, 2024
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
3/24/2024 2:38:44 PM • Vehicle Parts &... • Answered on Mar 24, 2024
3answers
What is hashtag
hash·tag noun
  1. (on social media sites such as Twitter) a word or phrase preceded by a hash or pound signand used to identify messages on a specific topic."spammers often broadcast tweets with popular hashtags even if the tweet has nothing to do with them"
    • the hash or pound sign (#)."Hunt mistook an @ for a hashtag while tweeting derogatory thoughts about him"
2/25/2024 9:46:45 AM • Vehicle Parts &... • Answered on Feb 25, 2024
Manual for XT-90LCD-autopage auto start
Yes
12/20/2023 6:51:49 PM • Vehicle Parts &... • Answered on Dec 20, 2023
Dynamite autopower DP-300 will not fully recharge no matter how long I leave it on the charger does not go above low charge
Hi, You need to check the output on the charger first, with a meter. Let me know and we will go from there.
10/22/2023 10:19:36 PM • Vehicle Parts &... • Answered on Oct 22, 2023
1944c Furuno radar array won't spin 7 years old. Just beeping
It seems like you're dealing with a technical issue related to a Furuno radar array. If the radar array is not spinning and is emitting a beeping sound, there could be several possible reasons for this problem. Here are a few steps you can take to troubleshoot the issue:
  1. Check Power Supply: Ensure that the radar array is receiving proper power. Check the power cables, connections, and any fuses that might be relevant. Make sure the power source is functional and providing the correct voltage.
  2. Inspect Mechanical Components: If the radar array won't spin, there could be a mechanical issue with the rotating mechanism. Check for any obstructions or debris that might be preventing the rotation. Lubricate any moving parts if necessary.
  3. Connection and Wiring: Examine the connections between the radar array and its control/display unit. Loose or damaged cables could cause communication problems and result in the array not spinning. Ensure all connections are secure and undamaged.
  4. Software and Configuration: Sometimes, software settings or configuration options can affect the operation of the radar array. Check the user manual or documentation to ensure that the radar is properly configured. Try resetting the settings to default and see if that resolves the issue.
  5. Error Codes or Messages: If the radar is emitting beeping sounds, it might be indicating an error condition. Refer to the user manual or any accompanying documentation for a list of error codes or messages and their meanings. This could help pinpoint the problem.
  6. Contact Support: If you've tried the above steps and the issue persists, it might be best to contact Furuno's customer support or a qualified technician for further assistance. They can provide more specific guidance based on the model of your radar array and the symptoms you're experiencing.
Remember, working with electronic equipment requires caution to avoid electrical hazards. If you're not comfortable troubleshooting the issue yourself, it's always a good idea to seek professional help.
8/9/2023 10:12:59 AM • Vehicle Parts &... • Answered on Aug 09, 2023
Passport SR1 Radar Detector Logo
Popular Tags
3 questions posted
Top Escort Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Escort Vehicle Parts & Accessories
Most Popular Question
looking machanical means starting lister
  • Vehicle Parts & Accessories
