20 Most Recent
Optoma EX615 DLP Projector Questions & Answers
It say no source found
Hello Abugah,
For "no source found" errors, we recommend starting with the input device and the wires (assuming you have selected the correct input on the projector). Swap wires and sources until you figure out if the problem is with the projector or not.
If you are using a computer, make sure that it is on the right settings. On laptops there is usually a button you can press to cycle through display options (normally a function key + another).
If you figure out that it is, in fact, a problem with the projector we recommend going to a professional to fix the problem. If you are in the United States we can fix the projector.
Projector AV Systems Repair Services
Before you send in the projector to anyone, contact Optoma to see if it is still under warranty.
Hope this helps!
How do I do a hard reset on a optoma uhd55 projector.
To perform a hard reset on an Optoma UHD55 projector, you will need to locate the reset button on the projector. This button is typically located on the back of the projector, near the power cord. Press and hold the reset button for at least 10 seconds, or until you see the projector's LED light begin to blink. Release the button and the projector will reset to its default settings.
My projector has a password locked but I forgot the password. If there is any way to turn it on, please help.
Optoma DLP projector
EX631
Reset instructions according to this
https://factory-reset.com/wiki/Optoma_Service_Menu
Optoma Service Menu Instructions
Most of our Optoma Service Menu methods require the use of an original remote, typically you can not do it with just the buttons on the front of the set. If you no longer have your remote or have damaged it, we recommend that you purchase a
Optoma Remote before trying to enter the service menu.
Method 1
- Press simultaneously {UP} & {ENTER} buttons twice.
- Press simultaneously {LEFT} & {ENTER} buttons twice.
- A Service Menu will be displayed
- Then to access the Full Service Menu: Press the {UP}, {LEFT} & {DOWN} buttons once.
- To exit, turn the Projector Off.
Method 2
- Press the {UP} {UP} {LEFT} {LEFT} buttons.
Method 3
- Press the {POWER} {LEFT} {LEFT} {MENU} buttons.
Method 4
- Press simultaneously the {RE-SYNC} {ENTER} {SOURCE} buttons on the Projector.
Method 5
- Press the {POWER} button.
- It will show: "Power Off" or "Picture Mute".
- Then press the {LEFT} button 8 times slowly.
Method 6
- Press {MENU} {6} {1} {9} {MENU} buttons.
- To exit the Service Menu: Press {MENU} {6} {1} {9}
My optoma projector has a green tint
it may just need a service, as all DLP projectors need to be cleaned internally as well as LCD.DLP projector images will flicker and lose colour also may shut down if it is very dusty inside.
