20 Most Recent HTC Flyer 7 inch 32GB Android Tablet PC with WiFi and 3G Questions & Answers
The noted 3G tells me the tablet will work as a phone but needs a sim card from one of the cell carriers.
HTC Flyer 7 inch... | Answered on Sep 15, 2016
If it won't charge then you may have a defective charger, a failed battery or a loose solder joint at the charging port. If your charger plug is fitted with a fuse then consider checking the fuse is okay by trying a new one. Also, check your charger on a friends HTC, check their charger on your HTC. It really is a process of elimination to find the issue yourself.
The HTC won't turn on because it isn't charged, until you fix charging prob it won't turn on.
HTC Flyer 7 inch... | Answered on Jul 13, 2013
Hold the power key down and select restart instead of power off. Takes about 30 secs to reload but then you are back to normal
HTC Flyer 7 inch... | Answered on Nov 30, 2012
Hi Tracey,
You may want to check their official website where you'll find the link to the apk : WhatsApp for Android
  • Download it and pass it on your tablet using your usb cable
  • Install with an explorer program (make sure third party softwares are allowed in settings)
Here you go !
Have a nice day !
HTC Tablets &... | Answered on Jul 03, 2016
The tablet might just be dead - if so, no point in investing in charger, is there?
HTC Tablets &... | Answered on Jul 25, 2015
u have 2 options 1 is to get the tablet reflashed or the most common problem is that u have overcharged the battery and it will need a new one this problem is very common in tablets as opposed to i pads as the tablets only get the bottom market parts where as the ipads get higher quality components
HTC Tablets &... | Answered on Oct 27, 2014
Leave it on until all power gone then hold down power button for 30 sec's and the try charging.
HTC Tablets &... | Answered on Jan 15, 2014
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
  1. With the phone turned off, press and hold the VOLUME UP and DOWN buttons, and then briefly press the POWER button.
  2. Wait for the screen to show the instructions on how to do the factory reset, and then release the VOLUME UP and DOWN buttons.
  3. Follow the instructions onscreen to factory reset your phone.
HTC Tablets &... | Answered on Sep 06, 2013
A simple one. The OS is android and that is what supplies the caclulator. The make is irrelevant.
Tablets &... | Answered 1 hour ago
Usually a bad connection from the plug on the lead, or there is fluff or dirt in the charging port of the iPad. First thing is try a new lead. Then shine a bright light into the charging port, is it clean in there? Buy some Switch and Contact cleaner and squirt it in there with the iPad powered down. Then blow down it. If it still does it, then it is a faulty charger.
Tablets &... | Answered 3 hours ago
HTC Flyer 7 inch 32GB Android Tablet PC with WiFi and 3G Logo
16 questions posted
Top HTC Tablets & eReaders Experts
270rexton
270rexton
matt
matt
Are you a HTC Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • HTC Tablets & eReaders
Most Popular Question
htc wont charge turn
  • Tablets & eReaders
