Try Data Recovery Software!
no root !
Can you retrieve deleted text messages on Android? Yeah, this video will show you the full guide for Android text message recovery. Don't hesitate and recover deleted text messages from Android 4.0, 4.1, 4.2, 4.4, 5.0, 5.1 and more versions right now!
Not only can you recover SMS messages from Android backup but also can recover Android SMS messages without backup. This video is showing you how to recover deleted sms messages on Android without root your phone.
Some common situations that lost text messages you can recover from:
1. accidentally deleted texts on your android phone
2. lost text messages after Android 5.0 updated or other Android upgrade.
3. save text messages from water damaged, crashed, broken or smashed Android phone
4. Android deleted text messages randomly by itself
5. Factory restore Android phone.
And more...
Watch this video and share it with your friends too so that they can also get their precious lost data back.
Sounds like your phone has had an unrecoverable error and may need to be reflashed. Please contact Motorola Support(1-800-734-5870)
for assistance or contact your service provider.
Motorola Support
WRONG! the electrify IS GSM Capible it is a dual mode phone CDMA AND GSM all you have to do is call us cellular and tell them you are going on vacation and want to use the GSM capibility and they will give you the proper code for your IEME. As for everyone else, atleast take the back cover off your phone before you post inaccurate info, or even better have any of you noticed the "Manage Sim" settings in the main menu? LOOK BEFOR YOU POST ****. I’m happy to assist further over the phone at https://www.6ya.com/expert/james_64a4cfc60afb91c3
1.Press the "Menu" key, and then tap the "Apps" option on the Electrify home screen to launch the Apps screen.
2.Select "Settings"to open the Settings app.
3.Click the "Language and Keyboard" from the list of options.
4.Scroll down the screen and then tap "Text-to-speech output."
5.Slide "Driving Mode" to switch it from "On" to "Off". The setting is saved.
Also check your Sound Settings (Settings > Sound) and Accessibility (Settings > Accessibility) to adjust these types of settings.
Mark
Motorola Support
I would try:
1)Remove thebattery, carefullyjumpercontactsphone power by somemetal object(screwdriver, knife...);
2)If it doesn'tturn on, try to charge thebatteryexternal battery charger.
Hi, are you using a bluetooth device with your phone to make the call?
Have you also checked while you are in a call the volume?
You can also check the troubleshooter that is available in Motorola Website:
MOTOROLA ELECTRIFY Silent mode Volume Vibrate
You can also find some helpful information here: MOTOROLA ELECTRIFY Make and answer calls
If you continue having issues you should check if your phone is having some physical issues, this might be affecting the quality of your calls.
Best Regards!
