20 Most Recent
LG Beacon MN270 Questions & Answers
I cant unlock my metro pcs lg beacon screen lock
It is usually the last 4 digits of your phone number. If you have
forgotten your phone number or the digits are not working, take the
phone to your phone subscriberu dial *22803 then it resets the whole phone and the ur passcode will
reset to the last 4 digit of ur phone number but u have to listen to the
voice prompts press 1 for english and it will ask u to prees 1 to
program ur handset
How can I unlock my LGMN270 BEACON
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
How to reset locked lg mn270
I forgot my lock cod
o enter your unlock code, LG phones often require access to a hidden
menu first. To access this menu simply enter the digits 2 9 4 5 # * 7 1 0
0 1 #.
1. Insert an original SIM card and turn the phone on
2. Access the hidden menu by typing 2 9 4 5 # * 7 1 0 0 1 #
3. Select 'Menu' and then 'Settings'
4. Next, select 'Security'
5. Select 'Network Provider' and 'Deactivate'
6. Finally enter the Unlocking Code provided.
(Please note: Some phones require a slightly different access
code - please see the list below if the above access code doesn't work
for your phone.)
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
